Transmission Replaced Issue Confirmed
Someguysomewhere26
united states
2025 tacoma SR5
Hello all, writing this to see if anybody else has had this issue as well as make everybody aware of what I’m having going on.
Driving today in the middle of driving, the transmission went to shift and it jolted the car so hard it scared me. It was almost as if I slammed on the brakes as hard as I could, and then continued to drive normally got to where I was going with no further issues and I’ve been parked the truck and left it.
Got back in it, not even 20 minutes later to leave, and as I was shifting from Park to drive it was jolting really hard more so than normal there’s usually a little bit of a jolt. I get that but pushing the truck forward
I tried shifting from reverse to drive multiple times and it repeated the issue
As I was driving back to where I was going, that same thing happened three times that happened earlier, where it jolted the entire truck in the middle of driving or what almost felt like slamming on the brakes or a really rough shift. It’s kinda hard to explain the entire truck felt like it got slammed for a second and then kept going
Twice when it happened, it happened as I was slowing down and it was a really, really really hard shift.
Then when I got where I was going, and I parked, and I switched between driving and reverse and parked, it was acting perfectly fine.
I apologize for the long ride up. I have an appointment tomorrow. Will keep you guys updated. Please let me know if anybody has had a similar issue.
UPDATE: I just received a call back my transmission was throwing no codes, and they tried replacing the fluid and flushing it and trying that to see if it resolved the issue.
However, none of it did and there is no code.
But the text said and I quote “ there is definitely something wrong with it”
Sent it off to Toyota and they said just replace the whole thing. Said hopefully ill have it back in a week or two.
UPDATE
Got the truck back yesterday few things I want to note.
I don’t have the paper work in my hand but it stated that the psi going thru the transmission was incorrect however it didn’t state what caused the failure.
Cost out of pocket would have been 12,500$
The truck shifts the smoothest it ever has even when I got it new (yes the transmission is obviously new now) but even the cold start first shift is gone at least in this sense it was before it’s barley noticeable compared to any other time it shifts.
This of course can all change I’ve only put 40 miles on the new trans but like I said before it feels different even compared to when I got the truck new.
Makes me think
1.My transmission was always funky and I didn’t know it
2. Toyota made some type of change and we don’t know about it
3. This take will be completely irrelevant when I start my truck next and it launches me into the atmosphere the first time it shifts.
All in all replacement went well here’s to hoping it’s the last one!
Mercedes
≈39N
2026 TRD Sport "Mercedes"
How many miles are on your truck?
I'm still breaking mine in.
FWIW, I have not encountered any odd behavior, lights or codes. Shifts as expected.
Good Luck :please: with your appointment. Hopefully, it's something simple.
Someguysomewhere26
united states
2025 tacoma SR5
About 6,800 give or take a few so thankfully should be under warranty regardless but still doesn’t make me feel good.
I always worry it won’t replicate at that exact moment or they will say something silly and band aid it and it blows right after the Warranty lol
Thanks for the good wishes definitely made me nervous
Someguysomewhere26
united states
2025 tacoma SR5
Want to add to this point I’ve had no issues other then the cold start first shift being rough which I’ve found is very common.
Mercedes
≈39N
Someguysomewhere26
united states
2025 tacoma SR5
Thank you for doing some research. I had to rush back to work so I haven’t really been able to look into it too much. I was aware of the recall in 2024 however I’ve never seen or heard of any other widespread issues going into 2025.
I’ve never had a transmission issue on any of my vehicles other than some of them starting to shift a little differently because they have 200,000 miles
However, whatever happened it’s not good. It just feels like a crap ton of pressure got pushed in all at once.
Or skipped or something
As of right now, no engine lights or lights of any kind will know more in about two hours when I leave work
I don’t know if I would word it as feeling like a bowling ball is falling out of my transmission though..
@Someguysomewhere26 You should check for transmission codes, which that kind of behavior might have thrown. In the 2024's the failures were caused by stuck/sticking shift solenoids, which threw specific codes. If you have any of them then Toyota might need to replace that transmission.
Good luck and keep us informed.
Many have reported under filling from the factory. Mine was about 1/2 quart low. Either way you’ll need to take it in to your dealership. Make sure they check the fluid level.
Someguysomewhere26
united states
2025 tacoma SR5
Dropped it off today since I’ll be working during my appointment tomorrow.
The shifting from park to drive got significantly worse the more I had to use it.
Notice the slamming while driving happens a lot more between 35-50 mph
Appt is at 8:30am tmr hoping they find the issue and fix it without much hassle. But who knows.
If it is a fluid thing for it to be causing this many issues wouldn’t there be damage done?
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
Im gonna guess you're getting a new transmission (if they can replicate it - good luck with that)
Someguysomewhere26
united states
2025 tacoma SR5
Thank you yeah that’s the big question. Can they replicate it?
It was doing it the entire time before I dropped it off. I’m gonna be really upset if it does nothing.😂
Should find out in the next five hours I’ll keep you guys updated. Thank you..
Someguysomewhere26
united states
2025 tacoma SR5
There were no codes or lights being shown unless I need a specific type of reader to see those.
Your ECU could have stored codes that would not show up on your information displays. OBD-II code readers are cheap and most major auto part stores will read them for you at no cost. It is worth it to have more ammunition in case your dealer tries lying to you, rather than fixing your truck.
Someguysomewhere26
united states
2025 tacoma SR5
I agree I do have one didn’t plug it in though didn’t have much time between work and dropping it off.
Will definitely check it when I get it back regardless thanks for the heads up.
Someguysomewhere26
united states
2025 tacoma SR5
Will say I didn’t know it could throw codes and no lights.
I’ve obviously seen multiple codes for one thing ect but good to know now….thanks
