"Recommended" (but not covered) Wheel Alignment at 15K mile service?
SilverSurfer
Tacoma TRD OR Premium Plus
I don’t see a reason to give the dealers grief for being stealers. It’s expected, right? They have a bad stereotype for a reason. Do a Nancy Regan and just say no.
Good Point. I'd tell the dealer to put it in writing that Toyota "Requires" Alignment at 15K for warranty coverage .... Of course they will not ..
Several times I have been at my former Toyota dealer and overheard them recommending service that I know did not need done. One lady had no idea and decided to trust them and let them replace the brake fluid in a 18 month old Camry. She had asked them to check something and after telling her it was normal, he said but to be safe you really need to replace the brake fluid. I almost stepped in and said "Ignore this creep - he is just taking advantage."
Miqie
2024 TRD Sport-Bronze oxide.
I live a few miles from Hunter Engineering. They used to give free alignments so they could train techs on various vehicles. They stopped doing it, unfortunately. I did it a few times.
It is starting to sound like an alignment might be a good idea, although this will be the first Toyota that I have had to get aligned so early. If 4th gens are out of alignment at low miles it seems like they were probably built that way. If so, why isn't the alignment covered by our warranty?
OldOre
OldOre
AC
TEXAS
2024 TRD OffRoad
Update: I went back for 20K service, no mention of alignment, but the service rep was terrible.
izzy
Bay Area
To be honest, it's not much of an upsell. Even if the alignment is done at the factory, there's no way it's still dialed in 5000 miles later.
Every single bushing and suspension part has to settle and break in. All new vehicles are probably way off by 5k miles until their first alignment. If you care about your OEM tires I'd say get it done at 10k or sooner before you can do some real wear on the tires... if you don't care about the tires just get an alignment with the next set of four.
Your steer ahead can be dialed in but your toe or camber could be way off (probably why TH / Pros are chewing up tires) until your first alignment.
I come from the car/tuner world where after you get coils installed you get an alignment immediately, and then again when the coils settle, a month later. A brand new vehicle isn't much different.
trailhunger
US
2024 TH
that pertain to only front coils? I'm set to upgrade my rear coils in a few months for heavier constant load...
izzy
Bay Area
Springs of any kind will settle, usually it takes about 500 miles/2 weeks of regular driving. The change in ride height is what makes the alignment go all wonky. Usually you get toe out when a vehicle ride height gets lower (new springs settling in).
If you're having a shop do the rear coil install maybe see if you can't make a deal with them for an initial 2 wheel rear alignment then a second 4 wheel one 1000 miles later.
To the op, when you buy a brand new truck/vehicle, it's probably sat on the lot for a while so maybe it's half broken in, but the alignment changing in the first few thousand miles wouldn't surprise me at all.
Slappy
tacoma , highlander
take it to a shop that does the laser alignment
rule of thumb is any new tires , wheels, new lifts ,suspension parts, you need a new alignment, if just for the insurance effect of not wearing/burning the rubber off your tires
i paid just over $100 to have mine checked & yes it was outta spec @ 1000 miles new
now goes straight down the freeway at 75+ mph , no slight correction needed anymore
these trucks are sooooo much Fun to drive🙂😎🤠
2024 Tacoma "Recommended" (but not covered) Wheel Alignment at 15K mile service? PXL_20250528_171658236
I don't know about others, but Goodyear shops will perform a free balancing and alignment check any time they are doing a tire rotation. I was shocked when Toyota says they do not check wheel balance when rotating tires, unless you pay extra for them to do so.
Dealership: rotate tires. Extra $$ for balance check. Extra $$ for alignment check.
(My closest dealership actually had the guts to tell me "you can't perform an alignment check without doing an alignment".)
Goodyear: if oil change or if tires bought/installed by them: free rotate, balance, and alignment check for life of the tire. Only extra money is for any weights needed or if the assignment is out and you want them to perform an alignment. The shop I go to will even check all fluids per the service interval and tell you if some don't need it or can wait to be checked again next interval.
As soon as the 2y/20k is up, the dealership will never see my truck again unless it's a TSB or potential warranty issue.
Slappy
tacoma , highlander
yup
. my wifes 2018 Highlander rear hatch actuators went out , Nave Motors did the work for half as much over the Novato Toyota quote & put on new OEM Toyota parts.
rchrds
TN, USA
2024 Trailhunter
One more data point- I'm at 25K on my Trailhunter, and...I hate to admit I have not been rotating my tires, as I should. Also hauling waaay over the "limit." I've found that my front tires are definitely wearing on the outside edges of the tread faster than the rest of the tire, though, to be fair, at my current tire wear rate, I'll be at the wear bars on all four tires in another 10K. It will be getting an alignment soon, because it is definitely no longer correct, regardless of what it was at the factory when I got it. For my money, the lifetime alignment at Firestone has been a really good deal- we keep our cars to 300+k miles and 20 years- that lifetime alignment is a winner over those time scales.
