Rusting bolt. Is this a problem?
vinstappen
Vincent
2025 Tacoma TRD Off Road Short Bed
I just noticed that a bolt connecting part of my rear suspension is rusting pretty badly. Is this something that will be a problem down the road and I need to report to Toyota and get replaced? This is a 2025 Tacoma TRD Off Road.
Unless you're going to coat every bolt end, this is normal.
izzy
Bay Area
Go drive offroad for a while and you won't even see the rust cause it'll be covered in dirt 🤓
That's really nothing, there's hardware on my truck that got a little coat of rust like that the first time I washed it (since it never got rained on, California)
ToyTaco
'25 Tacoma Limited (non-hybrid), '23 Bronco Badlands 2d SAS 7sp
We've found one application of axle grease provides several years or more of rust protection. Applied axle grease on boat trailers that we regularly dropped into salt-water---worked great. Although it won't last as long, spray-on Fluid Film works great, too. Our Limited has a coating on the inside of the main frame rails that feels/looks very much like Fluid Film
Muckle
Washington
I had a fun time removing those nutes when I swapped out my rear springs. It was much easier the second time around when I put the stock springs back on :crackup:
sabinjo
NJ
2024 Tacoma TRD Sport Premium
I noticed mine was exactly the same after about a month brand new and just assumed it’s normal surface rust and not a problem. It is a little shocking though when you see that on a truck with 300 miles but it’s fine.
VB Taco
Virginia Beach, Virginia
I saw that also early on with owning the Taco so I ended up cleaning off the rust and put a coat of anti-seize on to make it easier down the road when and if I decide to upgrade the suspension.
TrustButVerify
central
Several
Clean it off, hit it with a very judicious, almost homepathic, spray of "rust reformer" then top it with CRC corrosion protector, woolwax, surface shield blaster or fluid film.
Airborne
Upstate,NewYork
Ugh…….This is a truck, a 4x4 off road fully capable truck. Able to be full of mud, sand ,ruts, rocks, brush, branches ……..perhaps first truck, i dont know you..but FFS…. Some surface rust on a bolt, c,mon. Use your truck, drive it, enjoy it, put a scratch, ding or dent and get over superficial issues,
