Trailhunter lift options
MrJetset
Jon
Hoschton, GA
2024 Tacoma Trailhunter, 2010 Tacoma TRD Off Road
Got it. I’m curious how it improved the ride quality if the springs are stiffer - is it the additional travel
I am not an expert so I am not quite sure what makes the ride better. The fronts are about the same length with a couple more coils in them. Maybe that effectively makes them longer? Maybe since the OE springs were more compressed under stock load they are closer to the top of the compression of the spring? The rear springs are quite a bit taller and have more coils so that one is obvious. I would bet that the back end would be quite bouncy without any kind of load back there however.
I was expecting the same harsh ride with a bit of a lift, but they have definitely made the ride smoother. Very noticeable over railroad tracks and potholes. If you don't plan on much of a load, I would go with the 817s in the rear, but with about 300-600 lbs in the back the 819s are the way to go.
The Peak 1" did a great job up front, no change in ride comfort from stock.
For the Dobinson, you may have to take a little gamble depending on what you want. Below is a screenshot for the rear spring options showing potential lift/load. Keep in mind these lift numbers are for an SR5 or TRD Sport / Off-Road truck, not the Trailhunter. Supposedly we have a 1" lift in the rear already and I think that is a spring lift so you would need to subtract 1" from the lift numbers for what will actually be achieved against the stock Trailhunter. My suggestion would be either the 869 or the 817 depending on if you want .25" of lift or 1.25" of lift. If adding the Peak 1" lift, I would definitely go with the 817 (personally). All this assumes stock load.
As for comfort, I can only speak to my experience with the extra 400# of weight I am carrying. Others have added various Dobinsons in the rear and reported similar comfort to stock.
Good luck!
Got it. So the 817 gets me the greatest extension / lift with the lowest spring rate, correct? And our OME shocks have that much additional travel? Would you say the 817 is a similar spring rate / tightness to OEM spring?
I am for sure looking closely at the 817s. I don't mind "bouncy" but would love the smoother ride over bumps. Did you do both fronts and backs?
MrJetset
Jon
Hoschton, GA
I did. 820s in the front. There are some pics above.
Oops - now I see the pictures. Great stance on your truck. It's crazy to me that we have that much travel to play with in the shocks. Does this mean you have more compression stroke but less rebound? Sorry for the dumb question. And for the 820 in the front, what would be equivalent to the 817 in the front in terms of spring rate?
MrJetset
Jon
Hoschton, GA
Yes the 820 and 817 will pair well together with probably up to about a 300 lb load.
Yes to the rebound question. I expect less rebound. I haven’t had it out on the trail yet to test it.
That helps - I need to refresh my understanding of how compression and rebound travel impact performance and ride in various situations - I suppose it could impact droop articulation but I’m not entirely sure
JaidenA
Jaiden
Salt Lake City, Ut
This is a huge help for me!, Added a lot of weight and definately squatted a lot. Smaet Cap, RTT, 14 water tank, front bumper, wincvh and more skids. Think I will do the 821's up front ad the 822's in the rear. Thanks again for the great info!
YukonTRD
Whitehorse, YT, Canada
2024 Trailhunter
You had mentioned videos on the Peak website, to help with installation.. do you have a Peak spacer as well, or was it just the springs that you had installed?
MrJetset
Jon
Hoschton, GA
No spacer, but they have good videos on how to take your coil overs out and reinstall them.
JaidenA
Jaiden
Salt Lake City, Ut
Installed Dobison 822's and 821's today. Was pretty labor entensive but super happy with the results. They will be getting field tested in the Maze District of Canyonlands this week! Pics to follow soon.
MrJetset
Jon
Hoschton, GA
Any pics yet? Curious to see the results of that combonation!
SirLeigh
North Carolina
2025 Tacoma Trailhunter
Question for you guys. The back is a little easier to figure out which I need, but for the front I plan on putting on a steel bumper and winch relatively soon. Will the driving be obnoxious before I put it on if I get the higher weight option for springs?
wolfpackwest
Paul
Arizona
2026 Tacoma Trailhunter
Just got done installing Dobinsons springs rear and front on my TrailHunter Long Bed. I went with C59-820 in the front and C59-819v in the rear. I have about 300 lbs of weight in the back with the Decked system and items in the drawer. The front netted me about 1" more height (22.5" to 23.5" as measured center of hub to fender) and about 2.5" more height in the rear (23" to 25.625" as measured center of hub to fender). First two photos are before but with added weight with the old wheels and tires. Black springs were stock TH springs and the red are the Dobinson
Any chance we could get a few more daytime photos of your truck/setup? Im super glad I came across this thread - as I'm now considering just going with a spring upgrade on the stock OME struts, to gain a little lift/accommodate extra weight while keeping a comfy ride. But definitely curious how it's been holding up and how you're liking your rate combo.
