Trailhunter OEM Onboard Tire Inflator/Air Compressor Retrofit into Tacoma Offroad Premium DIY
Kodachrome
2005 Tacoma TRD Offroad, 2026 Tacoma Trailhunter
This video has brief shots of the back of the OEM compressor set. He’s retrofitting into an Offroad Premium. Also has a good walkthrough of the functions.
Thanks, with some patient freeze-frame, that helped enough.
I'm almost positive I have found a place in my camper to re-locate it to, can access disconnects from the turnbuckle assess hole. Once I get the truck, I will pull the controller out of the bed and figure out what do to next.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Cool. Sounds like you’re confident that your existing camper will fit. Is it worth a fit check before you remove the compressor?
Curious about the process an am excited for your new build once your Trailhunter materializes.
Kodachrome
I'm fairly confident it will fit based on measurements at the dealership, etc. But I am not one to take chances so I will make sure I am 100% of the fit and securing of it before I start making any adjustments. So it will be a slow process initially making sure the wide fenders clear the jack brackets, etc.
