TRD Pro Pulling to the right...
james cole
Bronco
Hello guys,
Brand new 2025 TRD Pro is pulling to the right, checked alignment and it was slightly off but still pulls to the right, are you guys having the same issue?
Thanks
JC
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
My TrailHunter also pulls to the right. Checked tire pressure and both right wheels are one psi lower than left. Didn’t check alignment. The veer is just slight and I only noticed yesterday after driving for a week.
SnowmanJPS
Halifax, NS
2025 TRD Pro
I haven’t noticed this coming from my 25 pro I’d be taking it in for that
Starman202
RTP, North Carolina
2024 Tacoma TRD Pro
Straight as an arrow for me....though I should add, my allignment was slightly off after 6 months [I only noticed it visually]. It wouldn't hurt to get that checked. Remember, as long as you're within 12 months or 12,000miles, you get 1 free alignment and wheel balancing if it's out of spec.
james cole
Bronco
Already did alignment, camber was a bit off, the problem apparently is thrust angle is at .27
any way to adjust rear alignment?
24TacomaGirl
Robyn
Same!!
Make your dealer figure this out, because it is not normal. I have been driving my Pro for 8 months and it tracks straight and true, as your's should too.
james cole
Bronco
Its very slight…
also could you guys check the following for me?
Is your PRO rear axle shifter about 1/4” to the passenger side?
SnowmanJPS
Halifax, NS
2025 TRD Pro
very superficial, I use the fenders and the passenger rear axle sticks a bit more than drivers.
now that you mention this I did notice this issue but I wasn’t on level ground when I seen it, I’ll see if I can get some level ground and check it out
@james cole The best I could do to get an objective measurement was from the inside of the rim to the outside of the frame. Mine is shifted about 1/8" to the passenger side by that, but I have no idea how accurate that is. I also don't know what an acceptable tolerance is or if that could cause it to pull to one side.
If you can reproduce the pull you should take to the dealer and let them figure it out IMO.
DialupDavid
Sam
Minnesota
2025 Tacoma TRD PRO
Crazy question, is the steering wheel off center? Had this before on a 4Runner (brand new) funny enough.
Otherwise no, my 2025 Pro does not veer off.
-Ideas:
*Hit a curb and bumped out alignment
*Bad tire balancing (if stock, unlikely)
*Bent Tie Rod or other suspension components.
If it's brand new I wouldn't mess around with it and make the dealer fix it.
Wouldn't be too worried, and make them give you a nice new 4Runner to play with while they fix it.
STrooper
Jaime
Houston TX
2025 TRD Pro
I just had the dealer redo the alignment on my 2025 TRD Pro with 9,700ish miles today after telling them it was veering right and the wheel tracks off center a little. I drove/rode with the tech that did the alignment and he did not notice it. Still redid the alignment to spec and filled the tires at equal pressure. I got it back a few hours later and the problem persists albeit less than before. I want to take it to the dealer down the road to see if they have dealt with the same issue as it seem to be a recurring problem based on this thread. I just want the damn thing to track straight and true. SMH.
JP
