Toyota Wireless Trailer Camera System?
Benny
Jay
Oregon
Was anyone able to get this option on their 2024 Tacoma?
2024 Tacoma Toyota Wireless Trailer Camera System? IMG_0138
It’s the only thing missing from my Tacoma that I wanted..
Bcphoto3
Bill
Oak Ridge, TN
Same with me.. My dealer said that everything needed to add to Tacoma was in the system but when they tried to order it, there were none in US. They felt like it would become available soon (within 6 months) as a dealer installed option. Question is what you need to add the system if you have a Trailhunter already with digital mirror and maybe ECU to drive the system..
Swizzard24
Swizz
Rhode Island
2024 Tacoma Off Road
Came installed on my 2024 OR Hybrid. 8/9/24. Very useful. Has a learning curve to specific trailers that can be stored. Great backing up to hitch. Only used it once. Dealer said don’t tow for first 1500 miles. Pulled 6000’ no problem. Only towed a couple of miles to home. Wouldn’t pull that for long distances but was great. Love it.
This system is NOT the trailer support bonuses that are in the truck software for assisting backing up or seeing the hitch.
This system is an extra communication setup that talks to a wireless camera unit you mount on the rear of your trailer. Then the truck can change the rearview mirror to be that camera rather than the truck rear (which now just looks at the trailer).
The factory force-removed the feature from my build saying parts were not available.
It's comprised of two additional roof antennas, the remote battery operated camera unit, and then the internal wiring and computer to link into the main dash and cameras. The antenna setup ensures the camera stays connected during left and right turns.
Even without it, you can set the truck to adjust blind spots for a trailer. You just can't "jump" the rearview image.
There are other threads on here where a lot of exploring was done to try and figure out all the parts that would be needed. But we need someone with it to see if their roof is also molded different for the addition positions, because I see no markers or flat spaces on mine for where you would drill and bolt.
I thought that Toyota had made this work without the two additional antennas, and they were just on the prototypes.
That was a running change to production trucks, so they are not on most trucks. I think that you can still add the trailer camera system without those.
I know some of you guys have this setup. Do you still need those other two antennas or does it work without them?
RESQCAT
Dennis
North Bend, WA
My Trailhunter had it OEM. Camera pairing has proved to be problematic. Camera 1 did not pair. Camera 2 worked, but I damaged it (dang it) and replaced it with Camera 3. Camera 3... trying to pair but so far no joy.
And the camera is HUGE compared to the Garmin I had on my T@B 320S Boondock. It feels as big as the trailer! But when it works it is pretty cool...
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Mine doesn’t work without the two antennas.
So I wonder if the problem is not having the other antennas, or just camera integration issues with that whole system?
It seems really flaky for a lot of people like @RESQCAT and I am glad I never went ahead with that.
RESQCAT
Dennis
North Bend, WA
Yes, so far a disappointing experience. For the price of the system, and the fact that the cameras are made by Panasonic, I would think we could expect a better one. But I will keep trying - I know the system can work as it did initially. Really wish I had not dropped camera 2 - antenna housing cracked... water intruded. Fzzzzzzt! Water good for hydrating. Water bad for electonics.
Will721
Will
Quad Cities
2025 TRD OR
Nah, you just didn't use enough water. There's a tipping point where there's enough water the low voltage can't transmit through it and it starts helping just keep things cool. It's like when you drink salt water, you just gotta drink enough of it that it the delicious water out weighs the salt before the sea madness gets ya.
RESQCAT
Dennis
North Bend, WA
Good tip. We have plenty of salt water here in nearby Seattle.
lauren01
Lauren
Ventura, CA USA
Mine has been a similar mess to get working but finally it tests out working at home. Road test pending. Our truck is a ‘25 TH long bed with WCS. A unicorn with bent horn :)
