disabling DCM / telematics in 2025 Taco
bobinoregon
Bob
oregon
2025 Taco
Posting a how-to on grounding out the antennas used by the DCM telematics module.
This post is not a debate about the puposes of telematics communicating data back to a toyota service center ,or legality of same -- only a how-to for those interested.
Background - why bother?
- All recent toyotas have a always-on cellular connection to Toyota corporate via thee internet. This enables lots of data reporting and remote monitoring & control of the vehicle. This includes GPS location, speed and other data. Maybe you don't care, maybe you feel the pros of being connected outweight the cons; but some people don't want this data being sent at all.
What data gets sent?
I Refer you to the 2024 service manual where it says:
2024 Tacoma disabling DCM / telematics in 2025 Taco aaaa
The HOW-TO for those interested:
I know that on other Toyota models, pulling the DCM fuse results in a Check Engine Light. I Haven't tested this on my Taco; but i don't want a bogus CEL masking other legit causes for CEL. So i looked for a method to keep DCM communicating to ECU but not the outside world.
After some research I found this thread. This method takes less than 15 minutes and is completely reversable. Basically unplugging three oem cables and plugging in three terminated dummy cables which tell the DCM it's out of range for cellular and GPS. This does NOT affect any other cellular or GPS devices you might have in the vehicle.
First, I looked up the location of the DCM module in my 2025 Taco. It's behind the phone shelf/charging area just ahead of the shifter.
I purchased three 'Fakra Z Female to SMA Female Vehicle Antenna Adapter cables' and some 50-ohm SMA terminators off Amazon. The square Fakra Z shells on the jumper cables need to be removed leaving just the inner coax connector, becuase the Fakra shells are are too Fakrin' wide to fit into the Toyota DCM. Do this carefully so as not to damage or bend the inner coax connector fins.
Accessing the DCM is easy; the panel holding the phone shelf/Qi charger basially pops forward and unclips. Once loose it can be pivoted to the right allowing acess to guts of the console. The DCM is front and center.
2024 Tacoma disabling DCM / telematics in 2025 Taco 1_IMG_8358.JPG
2024 Tacoma disabling DCM / telematics in 2025 Taco 3_IMG_8360.JPG
The antenna leads are on the left:
2024 Tacoma disabling DCM / telematics in 2025 Taco ant
The latches for the connectors are at the front. I suggest using a right-angle tool such as a pick to push the latches inwards while tugging gently on the cables. They pop out easily.
2024 Tacoma disabling DCM / telematics in 2025 Taco 5_IMG_8363.JPG
Install the terminated jumpers into the three DCM sockets you just freed up. The connectors have a slight interference fit so they won't easily fall out.
2024 Tacoma disabling DCM / telematics in 2025 Taco 8_IMG_8368.JPG
You could probably? just let the jumpers dangle in the dash area but i wanted to take their weight off the interference-fit coax connectors at the DCM side. So I used an ahdesive-backed zip-tie mount and a zip tie stuck right to the front of the DCM, through wich i looped the three new jumper cables. Now there is no weight pulling down on the connectors landed in the DCM.
2024 Tacoma disabling DCM / telematics in 2025 Taco 9_final
I Pushed the three OEM cables back into the dash and let them dangle.
I started the truck at this point to check for any CELs... no problems found.
Reinstall the phone shelf/carger plate in reverse sequence. Start the bottom with the vertical fin connectors.
That's all there is to it. At this point the DCM will this it is out of range for both cellular and GPS.
Note: the OEM "emergency assistance"button and other "connected services" are now diabled, obvi, as it requres that built-in cellular link. I infer that pulling the onboard GPS antenna also functionally blinds the onboard oem navigation. If you use onboard oem Nav, the you could experiment with reconnecting the GPS antenna only I guess? YMMV.
This will NOT affect any carplay, cellular or GPS accessed via a paired smartphone.
2024 Tacoma disabling DCM / telematics in 2025 Taco 7_IMG_8365.JPG
ramble22
2024 Tacoma Limited Hybrid
Fantastic info, thanks for sharing. I opted out of Toyota telematics shortly after purchasing the truck, but will be doing this as well since I don't have full faith the the opt-out will be fully honored long term.
bobinoregon
bobinoregon
Bob
oregon
2025 Taco
That's a hell of a lot of work to wear a tinfoil hat, however I really do appreciate these forums for what people are able to figure out
Here are two articles on data collection and how auto makers are sharing your data with insurance companies:
1. https://www.komando.com/tips/privacy/car-companies-collecting-data/
2. Automakers Are Sharing Consumers’ Driving Behavior With Insurance Companies
"What it contained stunned him: more than 130 pages detailing each time he or his wife had driven the car over the previous six months. It included the dates of 640 trips, their start and end times, the distance driven and an accounting of any speeding, hard braking or sharp accelerations. The only thing it didn’t have is where they had driven the car."
Dirt
Greg
Eastern OR
Damn!
And this is exactly why I disabled mine in the dealership parking lot before driving the truck home. Not that I went as far as you did lol.
Still blows my mind that people are willing and gladly PAY Toyota to give them all of their driving information (locations/speeds/trips/ etc.).
Sancheesy
Shawn
Ontario
Thank you for doing the work. I saw a youtube video on this data tracking.
TrustButVerify
central
Several
A point about why this matters. I got a call from the dealership the other day. "We noticed your truck has just over 5200 miles but hasn't been in for its 5000 mile service."
Apparently in the 40 screens of fine print, somehow I agreed to share all my driving info with the lowest form of life on earth, a dealership. I just wanted to use the remote start. They decided to spam me with emails and calls as a thank you.
Dayen
Daniel
North Kingstown RI
2024 Tacoma SR 6MT, 1985 BMW 316 5MT, 2004 BMW 325i 5MT (sold)
Do we expect the modules to be located differently in any way on a MT car? I have the parking brake bezel that goes over half the surface the panels on a AT car cover
Dayen
Daniel
North Kingstown RI
Just completed the DCM delete on my MT SR, there are some slight differences to the manual transmission version of this DIY. You're going to need to remove the trim around the shifter before pulling the bezel as it is larger and harder to remove than on the automatic cars.
If you don't know how to remove the shift knob, you need to twist the ring right under the knob clockwise and it'll pop down the shift boot. Then you can twist the knob off and pull the entire trim piece off.
I used the right angle hose pick pictured in the cupholder and used a trim tool to shimmy more room between the HVAC and the front phone holder bezel. I then pulled gently and popped the clips out.
2024 Tacoma disabling DCM / telematics in 2025 Taco 1746751070838-me
The bottom right portion of the trim is a bit tough to get out, I may have slightly scratched the passenger grab handle but oh well. It appears that there is more access to the connectors on a manual car compared to @bobinoregon 's DIY, there were no issues with getting my fingers in there.
2024 Tacoma disabling DCM / telematics in 2025 Taco 1746751294404-x
Glad to get the snoops out of my truck, seem to have no errors but I did not test if I have a working microphone or not. Will update when I drive the truck tomorrow.
Dayen
Daniel
North Kingstown RI
Just called my buddy from android auto, microphone works!
ShawnJon
Fresno
Ive seen a thread stating that even if those plugs are removed or unhooked if you get near a cell tower it can still grab info from the dcm. Did you remove it fully or just unplug the antennas?
Droid
Wyoming
25 OR MT
I went with this solution (bought it, even though truck is still on the way): https://www.autoharnesshouse.com/store/AHH-DCM77
This supposedly works and no power goes to the DCM at that point, so the cellular modem is genuinely dead.
EDIT: This does not seem to work properly. May try it again but it seems the microphone does not work with it. Same behavior as pulling the DCM fuse.
JayTech
Jay
2025 Toyota Tacoma TRD ORP
Has this caused anyones remote start via the key fob to stop working? Toyota claims the DCM is required for remote start to work at all even from the key fob as without the 10 year free trial or paid subscription to Connected services, you will lose access to remote start.
Droid
Wyoming
25 OR MT
I would recommend not pulling the GPS antenna wire. I think it's the center one. GPS does not transmit. It will theoretically prevent the vehicle from storing location data locally, but I don't think it's doing much/any of that.
The head unit furnishes the GPS data to Android Auto and CarPlay. It's much more accurate than it is coming from the phone, as it's roof mounted vs under a giant sheet of metal. You'll get a less jerky Android Auto/CarPlay map if you leave the GPS intact. I'm assuming it still actually works when the telephone antennas are terminated...will find out when my cables/terminators arrive.
Also on the subject of cables and terminators.... One of the amazon reviews is saying that particular terminator is crap and not actually terminating the signal. I ordered some from Mouser Electronics instead. 712-2467938-1 terminators and 523-095Z820159012 cables. Definitely more expensive. Probably safe to still buy cables from amazon. TBD if these work well at all, they're in the mail at the moment. The Amazon ones might be just fine, but I've 100% had it with that site and its fake crap.
