Starman202
RTP, North Carolina
I got the Suma mirrors installed. Nice field of view improvement.
I really want this as i'm spoiled by auto dimming mirrors [except for my Civic Type R, i had purchased Rexpeed blue mirrors for those]. I really wish SUMA didn't have the logo itched into the glass. But anyway, did you have to cut off the tabs on the mirror to make it fit?
Bravada
S.E. Texas
I didn't cut anything.
Bravada
S.E. Texas
Got my AJT DESIGN Shift Knob installed. The spring clip holding the original knob on gave me a little resistance, however as the Borg say, "Resistance is futile."
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 2025-04-02 23.05.29
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 2025-04-02 23.30.00
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 2025-04-02 23.36.22
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 2025-04-02 23.36.08
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 2025-04-02 23.36.12
timetoeatpotatoes
site
TH
Hey bravada do you have any fitment problems? AJT shift knob causes the truck to think I am not in park when I am in park.
I reached out to AJT and they kinda gave me the runaround and told me to try to lift it up and have the set screws hold it up but it binds up.
Bravada
S.E. Texas
So far no issues. I believe it came with instructions to not bottom it out on the Tacoma.
timetoeatpotatoes
site
TH
thanks, ill give it another go. feels like either it binds up (too high up) or does not think im in park (too low?)
Bravada
S.E. Texas
I'll try and make a short video later, to show it functioning.
TX-BluStreak
Houston, TX
2025 Tacoma TRD Pro
I just installed these billet tie down points on my 2024 Tacoma TRD ORP. If you want a pair, head over to https://billettiedowns.com/ and use code β€œGHOSTED” to save on your purchase!!
I bought a set of these but I'm having a hard time removing the OEM from the spray-on bed liner to install these. Pls advise. Thanks!
Halifax, NS
2025 TRD Pro
Added Versatrax for some extra tie-down locations. When the rings are removed the tracks are flush and bed mat lays flat over the top.
You’re today’s bad influence, these costed me a ton with tariffs but I LOVE the idea, I am going to trim my rubber mat to fit the front anchors better but that might be a Sunday issue
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_5342
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_5341
nurp42
TRD PreRunner
'24 PreRunner
Sorry about the extra $$ you had to pay, but yeah, I think you'll find them helpful.
Bravada
S.E. Texas
I bought a set of these but I'm having a hard time removing the OEM from the spray-on bedliner to install these. Pls advise. Thanks!
Your rail end caps are stuck on with the spray-on bedliner? Or the tie downs on the floor of the bed? When I installed my front bed Molle panel, I had to take a razor and a pick to get the bolts out of the bed floor. I cut carefully around the bolts, and used the pick to dig out the bed liner from around and in the head of the bolt, so I could get the bit in the bolt.
