did this and now i get the error "system malfunction" whenever i put the truck in reverse. no backup camera or 360 camera now.
Did you tap the dedicated dashcam connector in the roof pod or did you unplug your front camera module connector during this? You shouldn’t ever unplug that as it will throw all kinds of errorsdid this and now i get the error "system malfunction" whenever i put the truck in reverse. no backup camera or 360 camera now.
i didnt unplug anything. just connected right into the factory slot in the roof pod like the post says. Just went into the service menu and the cameras function doesnt even pop up.Did you tap the dedicated dashcam connector in the roof pod or did you unplug your front camera module connector during this? You shouldn’t ever unplug that as it will throw all kinds of errors
Sounds like you might have blown the fuse. Check the wiring and what you have plugged in. Something isn't right.i didnt unplug anything. just connected right into the factory slot in the roof pod like the post says. Just went into the service menu and the cameras function doesnt even pop up.
Any clue as to what fuse that may be? Can’t find anything related to camera.Sounds like you might have blown the fuse. Check the wiring and what you have plugged in. Something isn't right.
It's either ECU-B or ECU-DCC depending on your build date. Could also be ECU-IGR.Any clue as to what fuse that may be? Can’t find anything related to camera.
No luck on the fusesIt's either ECU-B or ECU-DCC depending on your build date. Could also be ECU-IGR.
And in case this isn't obvious, take out what you plugged into the dome light camera connector. Something is not wired right.
Hard to know beyond that without knowing what went wrong. Possibly one of the connectors above the mirror came loose during install? Otherwise worse case is the 12v shorted to neutral and fried something.No luck on the fuses
That’s the plan. Have an appt may1 and there’s no signs I was ever in the top compartment.Hard to know beyond that without knowing what went wrong. Possibly one of the connectors above the mirror came loose during install? Otherwise worse case is the 12v shorted to neutral and fried something.
Without knowing what went wrong I'd check all the fuses and then probably take it in to the dealership and plead ignorance.
I'm pretty sure there is a setting to turn off the the parking mode. I can't check right now but I'd assume it's in the parking mode settings. I've had better luck changing things on the camera and not through the app. Otherwise if you don't want parking mode at all you can just not hook up the constant on.This write up is great Thanks OP... I finally got around to unhooking my Dongar pro and using the 5 pin it came with to the viofo hardwire kit... I had a question for anyone using the viofo A229 pro.... Is there a way to turn off parking mode and also has anyone had a dead battery yet? What's the longest people left their truck and come back and started right up? Thanks
Just nervous to drain my battery
