Aspire V2 Fang Lights install - 2025 TRD Sport
Matt
New Jersey
2025 Tacoma TRD Sport
I just finished installing the Aspire V2 fang lights on my Tacoma. Whole install took about 45 min, but 30 of that was getting the factory plastic pieces off and zip tying the wires out of the way.
Legitimately plug and play. Once the Fang light is in the bumper, you untwist the yellow turn signal bulb, take it out of the housing plug it into the female end of the prewired adapter, plug the other adapter end into the truck wire housing and put the bulb back in.
I finished in the dark, so pics aren't great. But will upload new pics later
2024 Tacoma Aspire V2 Fang Lights install - 2025 TRD Sport 20250603_193804
2024 Tacoma Aspire V2 Fang Lights install - 2025 TRD Sport 20250603_200516
2024 Tacoma Aspire V2 Fang Lights install - 2025 TRD Sport 20250603_203557
EastonTaco
Venice FL & Easton PA
Looks great! Couple of questions; Do they stay on when the headlights are on at night and if so do they provide any additional lighting without affecting oncoming drivers? Are they on with day time running lights? Can they be wired so they only come on with one of the Aux switches that are on some models like the TRD Sport?
Thew_Tang_Clan
Matt
New Jersey
They do stay on while the truck is on. They aren't projected, so at night they make it brighter in the immediate area in front and to the sides. Maybe 10-15feet. Like a brighter glow. I can't imagine they are affecting oncoming drivers and definitely aren't high enough or directional enough to be too bright for someone you're following.
Out of the box, these were already wired into a harness that plugs into the turn signal light bulb plug, so without significant modification, you wouldn't be able to set them to an AUX switch. There are others available on Amazon for half the price that i am sure you can wire to whatever you want to, depending on your ability.
GHY
Gary
Southern Vermont
19 Boxster S, 23 Mach E, 24 Taco Sport 4dr/6ft
I’m very interested in these. Thanks for sharing. Did you have to remove the bumper or grille? I can’t locate installation instructions.
Thew_Tang_Clan
Matt
New Jersey
No, I didn't have to remove bumper or grill. To get to the tabs that secure the factory plastic trim, I did have to jam my arms in behind the light housing and they got scratched up pretty good. So removing the bumper would make that easier, but I got it done without.
I couldnt find specific instructions either, but there are installations (with wiring) on youtube...Just skip the wiring part. This one shows the fuse placement very well.
Iqudayo
2024 Toyota Tacoma
This was actually a fantastic installation.
Very, Very nice work
GHY
Gary
Southern Vermont
Thanks for the info and the reply!
Rich R
Rich
South Carolina
Toyota Tacoma
I installed the Aspire Lights that I purchased from Cali Raised Hardest part was removing the fake vents. I have big arms and no way was I able to reach the tabs. I’ve seen forums on the lights and just about everyone who did not remove the bumper had Most of the tabs break off. I knew I was not going to reuse the vents so I decided to drill a 2” hole in the center of the vent and then open it up using a dremel I was then able to break off the tabs and remove the vents much easier then removing bumper or fender liner.
The lights were plug and play instead of using the supplied Add a Fuse I wired it to my #3 Aux switch works great
2024 Tacoma Aspire V2 Fang Lights install - 2025 TRD Sport IMG_1186
2024 Tacoma Aspire V2 Fang Lights install - 2025 TRD Sport IMG_1187
Cabo
Pacific NW
2025 TRD Off-Road i-Force Max
Thanks for the info. I was looking at these Aspire lights as well and liked the “plug-and-play” configuration. I was also thinking of purchasing and utilizing one of the pre-wired auxiliary switches. Questions: Is the #3 Aux the 5amp switch? If you turn-off the Aux 3 switch in the cabin does it disable the “fang” lights and allow all other light functions to operate normally? Thank-You for any feedback.
Rich R
Rich
South Carolina
Toyota Tacoma
I connected the rear supplied wire harness jumper that came with the truck it was in the glove compartment this gives you power to the rear of the truck also gives you access to the pigtails in the front this video was very helpful:
The main reason I did that was I ran Ridgid rear lights in my rear bumper.
there is another supplied harness you can use if you just want power to the front
Aux 1 Black wire 15 amp, Aux 2 green 10 amp, Aux 3 white 5 amp
used the thin white wire from the pig tail note not the larger white / black that is a ground.
The switch allowed me to turn the fang running light off and on put the amber blinker mode doesn't shut off it will flash even with the switch off.
Cabo
Pacific NW
That sounds perfect! Thank You.
tacomaSport2025
chet
new york
tacoma 2025 sport
Looks great, I’m thinking of buying for my 2025 sport. How difficult was it to remove the black inserts? I’ve seen some videos with them removing them from behind and other videos where they’ve taken off the entire front bumper.
Thew_Tang_Clan
Matt
New Jersey
I did not take the bumper off, just jammed my arms in behind the light housing and tried to disengage the clips. Scratched the s*it out of myself, but got it done. Someone mentioned using a drill/dremel to cut a hole in the piece, which would have been much easier
Reactions: WOW
