JustDSM
Justin
Ogden, UT
www.overlandtailor.com
2024 Tacoma TRD Offroad
Thought I'd pass on a few measurements taken from a spare Throttle Body and Throttle Body Elbow off of the Tacoma (it's the same for other T24A-FTS platforms like the LC250/4Runner).
Located what I think might prove to be a choke point.. Enjoy!
*My calipers aren't perfectly positioned here, but the ID of the TB is 60mm, which gives us a cross-sectional area of ~2827.4 square mm excluding the throttle plate/bar.
*Choke point located!
With an OD of ~47.75mm and a wall thickness of ~3.25mm, that is an approximate ID (at the radius) of about 41.25mm (~1336.5 square mm).
Devildog81
minnesota
2024 tacoma trd offroad
There’s only one cold air intake kit that replaces all that, and that’s one K&N makes correct? Someone needs to come up with just a replacement elbow for this.
Rsuperman
Rick
Midland
2024 taco hybrid offroad
How would we correct this without throwing codes?
Lennyz1
Len
NY
That elbow and TB are all post turbo. CAI kits only do pre-turbo that I am aware of.
Bravada
S.E. Texas
Stage 2 of your tune, has me saving up. :piggybank: I can't wait. Sounds like I'll be busy replacing several deficiencies to mo power.
JustDSM
JustDSM
Justin
Ogden, UT
VF will be producing these.
"Coming soon...and available for pre-order this week.
Tacoma/4Runner/ Land Cruiser 2.4L Turbo CNC Throttle inlet pipe.
- Dramatically increases the Throttle inlet pipe diameter. No longer restricting down to 40mm.
- CNC Billet Aluminum
- Designed in the USA
- BOLT ON compatibility.
- Replaced the tiny, restrictive plastic one with a larger volume CNC Replacement.
Will provide:
- Dramatically less intake restriction
- More flow
- Better throttle response
and more
Pre-order for introductory pricing of $325!"
Let them know OTT sent you! If 10 of you mention that OTT sent you, he's gonna discount them further to $299!
VF has requested that anyone wanting to purchase and get their "OTT" mention/discount, please email [email protected] and reference the throttle body inlet.
https://vftuner.com/products/vf-throttle-inlet-pipe-toyota-2-4l-turbo
Norsk
Greg
Downingtown, PA
Will provide:
- More flow
and more
How can we let VF know you sent us? Is there promo code we can use?
JustDSM
JustDSM
Justin
Ogden, UT
Great question!
Norsk
Greg
Downingtown, PA
I got email that my order is being shipped to me.
I need to look at mine and figure out how to install.
