2025 TRD OffRoad - truck still thinks the trailer is plugged in after towing
OGBugsy
Las Vegas, NV
2025 Toyota Tacoma
I towed my converted cargo trailer out camping A few weekends ago. Added the trailer in the truck and selected it. Plugged it into the truck and used tow/haul mode while driving. Everything went fine. That night I unplugged the trailer and ran into town to get us dinner. Right after starting the truck I got an error saying that a few systems were unavailable, to see the owners manual, the trailer was still detected and trailer driving assist was active. Once I started driving, a different error came up saying “trailer not detected please confirm yes or no”. I confirmed no and went and got dinner.
after that, every time I started and drove the truck, it did exactly the same thing. Even after hooking the trailer back up and towing it home. After I got home and unhooked the trailer. It was still doing the same thing so I deleted the trailer and boat that I had stored in the trucks trailer settings and still no luck.
I took it to Toyota and they first changed a break solenoid under the dash. That didn’t fix it so they said they needed to change the brake manifold and it would take 5 days to get the part. The next day they called and said it was fixed. That an engineer told them to unplug the battery for three hours, reinstall the original break solenoid and that was it. They told me to disconnect it in the truck settings next time before unplugging it from the truck. The r & r of the break solenoid was not on my paperwork and they left 2 of the 3 seat fasteners on the back floor (hybrid truck).
fast forward to today. I took my boat in for a service and I did exactly what they told me as far as the order of disconnecting and unplugging, and right away the truck is doing the same thing every time I started driving and drive the truck. It thinks the trailer is still connected and wants me to confirm yes or no.
Has anyone else had any issues with this? Any help would be greatly appreciated. See attached pictures for the errors I am getting.
So, the first note was telling you that certain features aren't available while towing, such as Lane Assist. That's not an error.
When it asked you, "Trailer not Detected, Please Confirm Yes or No." You missed that test. The answer is Yes.
OGBugsy
OGBugsy
Las Vegas, NV
2025 Toyota Tacoma
I tried selecting yes several times and no as well. It just keeps coming back every time I start the truck. If the features aren’t available with no trailer selected or attached to the truck…then yes, there is an error. Your sarcasm isn’t helpful.
TxGlenn
Glenn
Spring, TX
2024 TRD Sport
This is the same symptom I was having in my 2024 that was supposedly fixed with TSB 25TC07. I just got the recall work performed this week and haven't hooked up a trailer yet so can't definitively say if it fixed it, but you may want to take a look at that.
Great White North
Glenn
TRD Off-Road Premium 2024 Tacoma, 2018 Rav4 Toyota
I have a 2024 TRD Off-Road premium Tacoma. I experienced the same symptoms while pulling my boat last week. Once I disconnected the boat trailer, I was still getting prompted whether or not a trailer was detected. I ended up removing the trailer hitch and the trailer prompts stopped. My rationale for removing the hitch was based on the idea that the trailer prompts were coming from the rear camera detecting the hitch. A couple of weeks before these trailer prompts, I took the truck in to complete a rear camera programming recall. I will put the hitch back on and see if the trailer prompts start again. I hope this helps.
SpicyTaco
Harry
Midwest
2024 Tacoma TRD Pro, 2011 Land Cruiser
Same thing on my 2024 TRD Pro! So frustrating. It continued to happen for over 1000 miles, then suddenly corrected itself. I have towed a trailer since then and it functioned properly. No recall performed yet. I don't have any answers for this.
rybern
Albertville, AL
'25 TRD OR, 00 Taco 4wd, '21 Corolla XSE
I do find the wording confusing. It seems it might could/should be "No, the trailer isn't connected."
OGBugsy
OGBugsy
Las Vegas, NV
2025 Toyota Tacoma
Took the hitch out and the issue went away after the first start. Problem solved!!
Tyvm everyone for the input!! And Tyvm Great White North!! I never would have thought of it without your reply. Hopefully it’s something they will fix in the future. Let me know if yours is fixed after the work they did please.
Drifte
Colton
Iowa
24 Tacoma, 20 RAV4, 10 Tundra, 99 C5
Same thing happened to me. I turned the gain back down to zero on the trailer brake controller and it never happened again. My hitch is still in.
I too was getting the question for a trailer and I had already removed the hitch, so turned the brake controller back to zero and that seemed to fix it.
OGBugsy
OGBugsy
Las Vegas, NV
2025 Toyota Tacoma
both my trailers don’t have electric breaks so I never have used the gain function. I put the hitch back in today and no issues so far. Just seems like a very buggy system. Fingers crossed for an update that makes it more stable.
john877
Severn, MD
2024 TRD Sport
Toyota does have a TSB to reprogram the BSM which is the cause. I had my TRD Sport in the dealer back in January and had them do the reprogram. So far no issues. One thing I have found is to make sure you turn the vehicle off prior to disconnecting the trailer. Another annoying feature is that you need drive about 100 yards or so after restarting the vehicle before it detects no trailers.
So my procedure connect trailer, start vehicle and put in drive, answer yes (hold ok) when it ask is trailer connected. When done, turn off vehicle, disconnect trailer, start vehicle drive away slowly, it will continue to display trailer connected (don't acknowledge or hit back button), after about 100 yards it will display trailer disconnected, hit and hold ok button.
rybern
Albertville, AL
Good info.
I suspect that going into the trailer menu and deselecting the trailer may work.
