Anyone install LoadLifter 5000 air bags yet?
Muckle
Muckle
Mtnbikes
Minnesota
From what I can see, it doesn't look like the EZ Mount On-Board Air Compressor (25980EZ) has the option to allow you to hook up to it for air compressor needs outside of the air bags - is that correct?
It looks like if I want to go this route and replace my portable air compressor with onboard air, I would need to go the route of the WirelessAir Tank plus EZ Mount (74100EZ)?
I do have a backup valve they placed in the truck bed compartment on the passenger side in case my compressor goes out I can hook up a portable compressor.
Muckle
Muckle
What do you keep your air bags at (PSI) when not towing/needing them? I have them at around the minimum recommended of 5psi and the ride is jarring when not towing/loaded down...moreso than the Alldogs springs.
rchrds
TN, USA
I did install the cradles for off roading, they work perfect. I'm super satisfied with the air lift and recommend it.
Do you know the cradle part number you used? I'm looking at the universal air spring cradle, 52500- was this what you used? Did you need the spacer to bring it closer to the air spring?
Vidman
Rick
Mass
When I had the bags in my tundra I would drain all the air out of them when not hauling or towing. I know the manufacturer does not like that but i never had any issues in the 7 years they were on the truck and yes I had the cradles. They are a must when going off-road or putting the truck up on a auto lift
24 TRD OR
Greg
Albuquerque
24 Tacoma TRD Off Road
Yes, universal is what I used. I remember calling to check and it works perfect. I don't have a spacer from airlift. I have a spacer/collar lift from ironman 3 inch in front, 1 inch in back
Mtnbikes
Minnesota
The manufacturer and the person that installed them recommends 5lbs. When driving around town at that pressure I feel no difference in ride quality.
Muckle
Muckle
The cradles remove an inch or two of travel from the air bags so they are compressed more when cradles are installed. The ride was incredibly harsh for me - harsher than the Alldogs rear springs.
I'm back to stock springs in the rear with no air bags :cwl: It isn't worth a harsh ride 95% of the time. I'll deal with the relatively minor squat when towing my trailer.
Mtnbikes
Minnesota
Yeah. I don’t have cradles. Maybe that’s the limiting factor.
fzjeddie
Eddie
Bay Area, CA
2024 Tacoma SR5 4x4
I installed the air lift 5000s to my sr5. Install was super easy and they work great. I have yet to test it off road yet to see how it affects flex in ruts.
Mtnbikes
Minnesota
I’ve been off road with mine. Nothing crazy. I had no issues.
CaliTaco64
Hugo
2024 Tacoma trd off road
I installed them. I like them a lot. My situation is similar to yours, except I don't tow, my load is on the truck. Rack, tent, coolers, overlanding stuff. But, I'm unloaded most of the time, like you. I took a trip to the white rim trail prior to putting in the airlift. I used Timbren springs and still had a lot of sag. So, I was able to return those and I got the Airlift. Bring able to control it is exactly what I wanted. Air up when needed, return to stock suspension when I don't. (Yes, I keep 5 lbs of pressure in it as the manufacturer recommended). I did install the cradles for off roading, they work perfect. I'm super satisfied with the air lift and recommend it.
Hi I just ordered my kit. I have a king front and back kit on my truck 2 1/4 in the front and 2" in the back. When camping and dirtbiking I easly add about 1klbs I installef the Eibach 500lbs and they still sag. See picture below I Being I have a 2" lift in the back I ordered cradles and 2inch spacers just incase.
Thoughts?
2024 Tacoma Anyone install LoadLifter 5000 air bags yet? 20251011_072512
