Andrace
2024 TRD Off-Road 6MT
Interesting, I'm not a huge audiophile, but a plug-and-play kit is tempting, especially at that price. Thanks for posting.
goin2drt
KY
Really a great value to have it all together. Crutchfield speakers alone $490. Great value.
I'm interested, particularly since there is no cutting involved and can be reverted back to stock if needed.
Ruckus
2025 Tacoma SR5
Does anyone have any experience installing speakers like this in our trucks without any aftermarket amplification?
I want to pull the trigger, but I also know that in the past, door speakers without an amp leave a lot to be desired.
I do have the BeatSonic ENA 3T3 with an aftermarket powered subwoofer.
awpk03s
25 Tacoma TRD Off Road Hybrid
I also have BeatSonic, this is an enticing potential upgrade to me…
80W RMS speakers. Highly doubt the stock JBL amp is producing anywhere near that output. So you may notice some improvement over the JBL, but it wouldn't be anywhere near the potential without an amp upgrade as well.
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
Was just going to say. Upgrading the speaker is y going make much improvement. You’re going to upgrade your amp for noticeable gains.
TrustButVerify
central
Several
Speaker install or not, it's a good video on how-to door panel removal. Might as well throw some noise reducing insulation on those panels when you got the plastic off to help reduce road noise further.
VB Taco
Virginia Beach, Virginia
I definitely want to look more into this. It's sad when my GFs 2021 4runner sounds MUCH better than mine.
@Ruckus I have seen info on the BeatSonic ENA 3T3. Are you thinking about doing this upgrade even after installing the amp? Are you thinking the amp is not enough?
@maxx075 I take it that your implying that this along with the BeatSonic ENA 3T3 would be a great upgrade?
What about the back sub woffer behind the back seat on the drivers side? Will the BeatSonic ENA 3T3 help it too?
Ruckus
2025 Tacoma SR5
The 3T3 by itself is a very modest upgrade. My real reason behind installing it was to gain the RCA inputs for my aftermarket powered subwoofer, with any gains in my mids and highs being icing on the cake. The cake ended up with very little icing.
The 3T3 only has a peak power of 50 watts per channel and I believe 25 watts RMS - so it would be anemic in this application where the speakers are drawing 80 watts RMS per channel.
The more I've researched it, the more I'm coming to realize there is no magic bullet for the audio in our trucks.
Also a side note, the 3T3 is not compatible with the JBL system, I don't believe. Or atleast there are some caveats.
The root of the issue is that the factory amp doesn't produce enough constant power (RMS wattage) for those speakers to run where they perform best. It would be akin to trying to increase water flow (water pressure = RMS wattage) by installing a wider pipe (higher rated speakers). The issue still remains that you're not putting enough power behind the water.
Yeah, that is what I think too. I put in a Beat Sonic amp and it definitely helped, but it is now more like a nice basic audio system, and hardly premium. The whole sound system was designed to be cheap and I guess they hit that target. But to really make it great you would have to start with a good amp and change all of the speakers, particularly that removable thing.
Someday maybe, but just adding better speakers to a weak audio system is never going to get the job done IMO.
