Trailhunter auxiliary gas tank
TrustButVerify
central
Several
It's not the best option, but a $35 sceptre 20L tank from Canadian Tire mounted to the bed rails is hard to beat if you truly need the range. Don't think they sell them in the USA, but they are a damn fine gas can if you can find them. That's another 90 miles of range per can. Simple, easy, and cheap.
Scepter 4WD Vented Gas Can, 20-L | Canadian Tire
$37 now. I paid $35 last month. Crazy.
mtbocoee
Ocoee, TN
2025 Tacoma Trailhunter, 2000 Tundra, 2013 Highlander
I think that is available in the US, but it won't come with that spout. I would love to buy the Scepter heavy duty military version Jerry can, but they are only available to military or government personnel in the US. We are stuck with gas cans that come with CARB compliant spouts which don't work, and are one of the world's worst inventions to solve a problem that didn't exist.
For anyone interested, the Rotapax water can nozzle looks just like the one on the Canadian Scepter. It is available on Amazon, but does not come with Rotopax gas cans. It works on Midwest metal Jerry can so my guess is that it would work on the Scepter.
@mtbocoee Totally agree about those nasty spouts. It makes you wonder if the designers ever tired to actually use the damn things. I have spilled more gasoline using them than I ever did in the many years I have used normal spouts. Another example of government design by committee to protect the stupid from themselves.
rchrds
TN, USA
2024 Trailhunter
Apart from the very first tank, the Trailhunter has settled at ~15 mpg. Ten-plus consecutive fills cluster tightly between 14.5–15.6 mpg, with a single low tank at ~12.8 mpg while towing ~1,700 lb. That yields a practical range of ~225–230 miles per tank. Rather than the modest range gain we planned for, we’re seeing ~20–25% less than that target.
I concur with this. Non- towing my trailhunter is averaging 17ish, 14ish while towing, for an average of 14.9 over 25000 miles. Interestingly, my unloaded mileage has been creeping up into the high 18s, even on the highway as the truck breaks in some.
Not much spare space under the trailhunters, I carry a 5 gallon jerry of non-ethanol on my camper, and had to add the last 3 gallons to the truck to get off the mountain last week. I'd like to see a replacement tank that fits in the spare tire area- I can always put my two spares on the roof.
rchrds
TN, USA
2024 Trailhunter
Correction: you can buy Wavian gas cans here with CARB compliant stuff. You used to be able to buy the non-CARB spout from Wavian, but this is apparently no longer the case. I use one mounted to the side rails of my camper- never leaks, is fantastic. I added a link below for the non-CARB spout.
https://wavianusa.com/wavian-fuel-c...9ffbjaM2wkDJ3c6Y2Arb9oN_h8eMHsyDN7gO7p6T6WVuJ
Andy@AAV
Virginia
2010 Tacoma, 2022 Wrangler 4xe
Linked site says they come with a safety spout. Mine did, so did the dozen we bought for work. You can order them separately.
rchrds
TN, USA
2024 Trailhunter
mtbocoee
Ocoee, TN
I was thinking that last year in Moab Gearheads sold Wavian cans and offered a replacement spout for the one that came with it. I already have a Midwest can so I did not want to buy a new one. I have had this can for a number of years and this is the first time I have been able to successfully get gas out of it and into a vehicle without spilling with the Rotopax spout.
https://www.amazon.com/Roto-RX-SP-V...fix=rotopax+water+spout,automotive,168&sr=1-6
https://www.amazon.com/Moeller-Scep...fix=rotopax+water+spout,automotive,168&sr=1-4
The RotopaX version was about $15 when I bought it, though having a full gas can that you cannot get the gas into the car from it worth what is takes to make it work.
TacoDoc
2024 Trailhunter
eBay etc. Scepter is obtainable if you look.
mtbocoee
Ocoee, TN
I recently completed a trip from East TN to WA and points in between. The trip covered 7675 miles over varied terrain and driving conditions including 200+ miles of off road driving some in 4WH and 4WL. The trip began with roughly 2300 miles on my Trailhunter and finished just shy of 10k. I ran the truck across a scale and it was 6660 lbs loaded about 175 lbs below the GVWR. Here is a synopsis with actual data below. Note the truck includes the OEM roof rack and an Alu-cab contour canopy top with roof mounted MaxTrax, otherwise wheels and suspension are stock.
Average: 17.25 mpg
Plains SD, KS, etc. 75-85 mph Speed limit 14-15 mpg
White Rim Trail 2WD, 4WD H & L 12 mpg
Reduced speed and lack of wind 19-20 mpg
In some cases where gas mileage was high it wasn't clear why based on driving conditions. The same is true for some lower mpg results. It's possible the exact gas formula plays a role. Most but not all driving was in ECO mode, but since 4WD kicks it out of this mode I didn't always notice it was off. As others have noted, it is not clear that ECO has a significant effect on highway driving which covered much of this trip.
While the average MPG wasn't as bad as I anticipated based on others comments. The most frustrating thing as that I had to stop for gas at 200-250 miles where I generally drive 300 before stopping. There is one result below at 282 miles in ID where I ran 10-20 miles below what the truck says was empty. According to gallons added there should have been 1.5 gallons or more left so there is a little wiggle room in what "empty" is per the gauge. Nonetheless, it is concerning when you are in remote areas where gas is limited and far between. Needless to say, I would love to have a tank that adds 4-6 gallons to increase the real world range of this truck.
DateStateOctaneOdometerMilesGallonsMPG
8/30/2025TN/KY872547229.314.48615.83
8/30/2025KY872631844.99416.82
8/30/2025MO872896264.915.00617.65
8/31/2025IA873138242.214.15117.12
8/31/2025SD873397258.414.4517.88
8/31/2025SD873633235.715.98714.74
9/1/2025SD873830197.312.75815.46
9/1/2025ND874077246.613.58718.15
9/2/2025ND874252---6.202NF
9/3/2025ND874414337.612.41218.14
9/3/2025ND/MT874597182.311.96415.24
9/3/2025MT874851254.114.5417.48
9/4/2025MT874958106.76.12517.42
9/4/2025MT/ID875154196.39.76520.10
9/4/2025ID/WA8752901366.70420.29
9/4/2025WA875484194.710.30818.89
9/5/2025WA875734249.812.60419.82
9/6/2025WA875931196.69.92819.80
9/6/2025OR/WA87617124013.41517.89
9/6/2025WA876327155.510.20515.24
9/7/2025ID876609282.116.39117.21
9/8/2025MT/ID87678317411.14115.62
9/8/2025ID8769231407.60518.41
9/9/2025ID/UT877165242.413.57917.85
9/9/2025UT88 No EtOH7342177.49.26419.15
9/10/2025UT877582239.412.65318.92
9/10/2025UT88 No EtOH7725142.78.81116.20
9/11/2025UT887896171.110.26816.66
9/12/2025UT878072176.510.80316.34
9/13/2025UT87815077.64.0119.35
9/14/2025UT/CO878399248.718.75513.26
9/14/2025CO878597198.311.43417.34
9/14/2025KS878866269.314.81718.18
9/15/2025KS879066199.313.36814.91
9/15/2025MO879301235.513.43517.53
9/15/2025MO879530229.112.52318.29
9/16/2025KY/TN879764233.813.92216.79
9/16/2025TN879995230.312.47418.46
2024 Tacoma Trailhunter auxiliary gas tank IMG_0203
TFOUTS
Timothy
Northwest Florida
White Rim Trail! This is an awesome trip. As far as wanting more fuel on board, do you have the mounting capacity to add Rotopax? I carry two 4 gallon units. Also, I ran my gas tank down to empty, but when I filled up, I could only put in 16 gallons.
I saw the other day that Long Range America has an auxiliary tank for the 2025 Land Cruiser. They removed the spare tire and that is the new mounting area for their tank. I am eventually going to remove the rear ARB bumper on my Trailhunter and put maybe a YotaMafia bumper with a swing arm, where I will mount the spare tire. Then possibly mount an auxiliary tank in the place where the spare tire is currently mounted. This will obviously cost several thousand dollars.
mtbocoee
Ocoee, TN
I carried a 5 gallon Midwest jerry can and a 3 gallon Rotopax. I added the 5 gallon on the White Rim but could have made it off without it. I had time at the campsite and since I was starting back the day I left the rim I wanted to get rid of the weight plus make it a to Grand Junction before filling up. Also the gas was from TN where it is much cheaper than CO.
Here is another pic.
2024 Tacoma Trailhunter auxiliary gas tank IMG_0233
TFOUTS
Timothy
Northwest Florida
On the way out from Florida on my trip in June, I bought gas at a Loves' outside Oklahoma City on I-40. Notice the price, I could not believe it!
2024 Tacoma Trailhunter auxiliary gas tank IMG_5163
