Stolen Tailgates
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
guys can't we just disable the setting in the in the dash? the button won't open the tailgate if that setting is off. Am i wrong or missing something? Seems a bit unnecessary to unplug the button.
trailhunger
2024 TH
I just reconfigured my dash for the first time, will go back and take a look…
trailhunger
2024 TH
I just looked into my dash settings couldn’t find anything controlling the driver control console. Go ahead and toss up how you’re able to control those analogue switches from within the digital dash
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
I only know about this because my tailgate button didn’t work when I bought the truck. The dealer helped me figure it out.
2024 Tacoma Stolen Tailgates IMG_1685
2024 Tacoma Stolen Tailgates IMG_1686
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
Of course, they could still break the window and unlock the truck and still get into your tailgate. But I think at that point your truck is probably gone too.
trailhunger
2024 TH
That’s super weird I don’t see that setting, will triple check…
..that’s the thing tho, if the truck’s alarm is on/locked they can’t unlock the truck (cabin) after breaking the window. Roll down your window and lock the truck, get the fob in a faraday bag and test it.. if you manually open the doors with the vehicle locked yes the alarm goes off, but lock buttons are inop
EDIT: found it! Yea buried deep in vehicle settings. Good eye! šŸ¤™šŸ¼ gonna put black sticker over the button until I trade it in
ixo
Rich
Antioch, CA
2024 Hybrid Tacoma OR Premium
it seems like it would be trivial to wire something like this into the "AUX4" blank, and just use it to disable a single wire in the tailgate button, prohibiting it from working unless you ALSO held the button while pushing it. Or you could make it a hard switch, and "hide" it elsewhere, but thieves won't know to hold the second requirement to make your normal tailgate button actually work?
2024 Tacoma Stolen Tailgates 1758841682043-u3
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
Awesome! Glad you found it. Hopefully now you see my confusion. I was wondering why someone would go through the extra work to unplug and replace the physical button when you could just disable it in the settings.
Side note: it also disables the buttons on the side of the tailgate and the kick function too. It just becomes a regular manual tailgate.
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
Just disable the power tailgate and use it manually if you’re worried about that. But as @trailhunger said, once your theft alarm is on, the door locks turn off so the tailgate should power tailgate should turn off too. Emphasis on should….
Don Hoe
Don
Canada, British Columbia
2025 Tacoma TRD Off Roard
I don't think the 4th gens have aluminum tailgates. People have been stealing tailgates since trucks were invented, so it is not just a 4th gen thing. They are usually stolen to replace a damaged tailgate, which can happen pretty easily.
I find that just locking the tailgate keeps me safe, but if you often leave it parked in a sketchy area one of the locks could be useful. Of course all manner of other things might be gone assuming they are willing to break into the cab, but at least you would still have a tailgate
They are aluminum. A magnet will fall off.
Yeah, I took a magnet to my truck after posting that and they are aluminum, which I obviously never knew.
trailhunger
2024 TH
So…interesting wrinkle to disabling the power tailgate on the digital dash settings: once I deactivate it, my powered tailgate will still open by using the side buttons near the tail lights, but will no longer close. It’s odd, suppose not a dealbreaker for some but I’ve gotten used to using that Gucci tailgate motor. Disconnecting the button on the driver console takes about 5 minutes so net net that’s still the easiest way to disable that security vulnerability while still benefiting from near field communication & functionality with my fobs & phone
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
Even with the truck locked and keys not present, you can still open the bed with those side buttons? That's weird.
I have tested that, and the fob has to be in range to do that. You can open it with the buttons when the truck is locked if the fob is near enough.
