14 in displays going in and out?
TFOUTS
Timothy
Northwest Florida
24 Tacoma Trailhunter, 26 4Runner TRD PREM, 03 Tacoma TRD OR, 03 Sequoia SR5
Has anyone encountered that their 14 in display goes dark sometimes when the cameras are coming on driving slow or in reverse or out of reverse to very slow drive when the cameras are normally on? I put it back in park and the display came back on. Cut the truck off and the everything went back to normal. Today was a second time this week. It has to be software related. This is not the issue already out there about the cluster panel TSB
TH_Don
Alberta
2024 Trailhunter
Screen blanked out once in first 5000 miles during shifting between reverse and drive needed for low speed parking maneuvering into garage.
Sceen back after a restart.
Tom Sellick
Ontario
2024 TRD Pro
Happens to me once in a while. Goes black then comes back up. Was driving down the highway. Happened this morning.
B-52 Gunner
Gerry
Lansdale, PA
It's happened to me 4 or 5 times in 14 months.
It's a SAFETY RECALL 25TA08.
Fiigtaco
24 TRD OR
Yes mine actually did it for the first time last week, started the truck and instead of going to carplay or the default screen it was just black until i tried to switch stations withe the steering wheel controls.
Thats for the 12" MID not the 14" screen(radio)
This is part of the a safety recall problem - yes it’s happened to me - did my 20K at toyota today and they said there’s no fix yet
Fireguy67
Klaus
British Columbia
Has happened to me three times in a year and a half of ownership. Shut the truck off started it again and everything’s back to normal. Annoying yes but a real big problem -no.I brought it to the attention of the dealership. They’re looking into the probability of a software issue. This is not the same as the12.3 inch screen problem in the recall.
I have had that happen, but just a couple of times. There is no fix at this point, and there may never be one since Toyota doesn't even have fixes for some of the recalls at this point.
TFOUTS
TFOUTS
Timothy
Northwest Florida
I'm relieved that I did not have an issue with this while using MTS software out in the wild because I needed the cameras while rock climbing in Colorado and Utah. I have noticed that keeping the camera lenses clean is a must, but this is something that cannot be helped sometimes out in the dirt and mud. You know, something the truck was made to do.
TacoEd
Ed
Denver
2024 Tacoma TRD Pro Hybrid I-Max
There is a 12.3" Cluster issue you can read about here:
https://www.courtesytoyota.com/12-3-in-digital-gauge-cluster-recall.htm
I have not seen this issue in 8 months of ownership.
I just scheduled mine for reprogram/replacement.
The 14-inch multimedia touchscreen sometimes is black at startup:
This has happened around 4 or 5 times in 8 months (I'm about 20k now)
I have had it come back on by pressing the volume button in (Media On/Off)
or by shutting off my truck (and open door to remove power to display)
and then start my Taco normally.
