Lawrence, KS
2025 Tacoma TRD-OR
Ok, what issues? I sure didn't have any problems with my install. It was stupid easy.
Did you read the initial post where he talks about some issues he had? Also, if you've installed yours recently, maybe they fixed them?
trailhunger
2024 TH
I'm taking my TH in for 10K Toyota Care Service & probably Trailer BSM, will likely remove my 60 delete so everything is accessible for the techs. I have maybe the 2nd or 3rd build from GG for the hybrid rear deletes, no real issues removing the hybrid filters, I think the design is good, no complaints
Have the 40 delete also, but lately rocking a 3 seater haven't done huge trips as of late.
rchrds
rchrds
TN, USA
2024 Trailhunter
So I figured out a good use for all the wasted space underneath the Goose Gear seat delete:
2024 Tacoma Goose Gear 60% Seat Delete - the good, the bad, the ugly. battery
I wasn't really happy with the exposed battery connections, particularly after I added the SDHQ power relocation so I could power a winch on the front bumper. Lots of very high power exposed connections in this area, and I didn't want to start throwing stuff down there.
2024 Tacoma Goose Gear 60% Seat Delete - the good, the bad, the ugly. sled
I had one of these heavy plastic toboggan/sled/lava tube crawling tool hanging around, and figured it would make a good insulator for the battery compartment, as it is fairly rigid. (Paricon Flying Carpet is the official name.)
2024 Tacoma Goose Gear 60% Seat Delete - the good, the bad, the ugly. shet
It happens to fit perfectly. covers all the battery bits, and leaves an almost 5" (why?!?) high storage area under the platform. Ends up being a great place for storing all my recovery straps, bits and bobs. I had it stuffed on the floor in front of the third seat, but this is way better. All of this is above the level of the filtered vent, so air flow will travel below the sheet to keep the hybrid battery cool.
2024 Tacoma Goose Gear 60% Seat Delete - the good, the bad, the ugly. stuff
BuriedFriend
Stevie
texas
24 Tacoma TRD Pro
That does look good and functional, just make sure you’re not blocking air flow for cooling.
Wanderlust
Will
Denver, CO
2024 Tacoma TRD Off-Road - OTT Tuned
How's the cabin noise? I installed the 60% delete and noticed a significant increase in the road noise resonating in the cabin.
rchrds
rchrds
TN, USA
2024 Trailhunter
Yep there is an increase in noise. The seat absorbed a lot of the ambient cabin noise.
TrailAdventurer
JT
Canton, MI
They are passing my notes on to the crew. Hopefully it will get fixed for the next guy.
Actually, they did have use a '24 Trailhunter as dev platform. Independence Overland let them use his. So the 'didn't have a hybrid available' observation is incorrect.
We received ours mid-Summer '25. I ran into all the same issues the OP posted. Provided my own detailed feedback. They thanked me. Had the impression they appreciated the feedback, commented not having a '25 to look at for changes, seemed perhaps I was 'first with a 25' to comment.
Seems that's not the case. With ~6 months to address some notable problems, update documentation (I noticed same), one might expect better.
I still like the Goose-Gear offerings. But I'll admit this tarnishes the silver a bit.
TrailAdventurer
JT
Canton, MI
I have same. Feels like the left-rear tire is about 2' behind my head. I'll either install dynamat or, since I have to pull a chunk of the platform, may just put the seats back in. An expensive hit.
TrailAdventurer
JT
Canton, MI
The challenges seem to relate more with the hybrid installs from what I've seen.
Pappy
Albuquerque, NM
Oh, I don't have a hybrid, and I not only didn't have an issue with install, I happen to really like the kit.
Wanderlust
Will
Denver, CO
I ended up tearing out the back end and put in sound deadening on everything I could. It was driving me insane. Having Toyo A/Ts certainly doesn’t help. The truck came with the JBL system and I noticed the factory sub is ported to the outside of the cabin which is allowing noise to get through. I have plans to remove the sub and close that opening entirely, as I installed an aftermarket sub.
Big Dawgs Toyota Tuning
Quez
Nashville
www.bigdawgstoyotatuning.com
You have a pic of the sub installed?
Wanderlust
Will
Denver, CO
I do. It's not a professional installation by any means. I just did what worked for me.
2024 Tacoma Goose Gear 60% Seat Delete - the good, the bad, the ugly. 57e7065c-028d-4a69-bedc-1bba722f7b63
2024 Tacoma Goose Gear 60% Seat Delete - the good, the bad, the ugly. 04ceba1c-2857-4dfd-aef0-181f06531943
2024 Tacoma Goose Gear 60% Seat Delete - the good, the bad, the ugly. eade720e-7e90-4d8c-88fa-7205efb7628f
There are plans to secure it. The seat up against it is good enough to hold it down for now.
