Transmission needs to replaced at 230 miles.
Not that I am here to defend Dealerships per se, but I would think this is more of a Toyota problem.
Yeah - the transmission failures are on Toyota, but the dealer didn't check out the truck the first time it was in and used the lame "learning software" excuse to avoid doing their job. That is not the sign of a good dealer, but maybe there aren't anymore of those left at this point.
ixo
Rich
Antioch, CA
2024 Hybrid Tacoma OR Premium
Recommend any cheap ones?
They're a dime a dozen on Amazon, just search "obd reader":
That first one will be fine. The 79$ second one is nice if you don't use your ODB port for anything else (I have a scangauge3 attached to mine), and want to be able to just read (and screenshot, etc) codes on your cellphone.
choss
Cody
east coast
25 Trailhunter
I wouldn’t take the risk I asked for my money back and find a new truck
DENNISD
Dennis
Omaha
Until the warranty expires, the risk is really minimal at best.
If something is going to go sideways, it will show up before the expiration of the warranty but I get it, if you don't feel like driving that Truck I would certainly exchange it.
At least you would have record with the one that gave you issues to start with and it would be easier to twist arms with a known problem as opposed to a totally different truck down the road.
I personally wouldn't be afraid to keep it with a new tranny installed.
Even then, there's a TSB/recall and if anything else did happen, even outside of warranty and you have the same issues codes it's still covered.
My truck is covered under that TSB, but I was not aware that they would do anything once the powertrain warranty expires. If your are correct, that would give me a new perspective on whether I keep my truck long term or not. I don't think the TSB would even apply to trucks which are not in the VIN ranges listed, which I am sure this truck is not.
So TSB goes beyond the warranty?
I don't believe it does. I think it only clarifies what Toyota will do if your transmission is in one the VIN ranges listed in the TSB and is still in warranty. Once the powertrain warranty is over I think all bets are off and we are on our own.
izzy
Bay Area
If it was a recall yeah. They didn't do a recall because I assume there's a few cases where the transmission might have unintended shifting behavior, but it'll last 100,000 miles anyways.. they don't really care beyond that because the useful life of a vehicle as defined by manufactures. The emissions equipment is warrantied for 80,000 miles, so I think that's a decent determinator of what Toyota believes is the useful lifespan of a 4G Tacoma. The Hybrid battery is warrantied for 150,000 miles.
"Accordingly, staff is proposing a 0.005 g/mi credit toward the NMOG+NOx
standard for manufacturers who warrantee their vehicles’ emission control systems for
the full 15 year/150,000-mile useful life."
Toyota turned down this emissions credit and stuck with 80k. Says something to be honest.
So you wind up with people complaining, which is valid, but their truck wasn't going to break right away. The fix though, is still simply replace the transmission, because Toyota dealerships do not repair stuff, they just send out the busted core and it gets recycled/re-man.
But for the ones that blow up off the lot, they'll replace without question. These cases are the minority.
I decided to get the 10yr/125k mile and I'm praying if the trans goes it'll go before the warranty is up 😂
Super helpful - I also got an extended warranty to 125K thinking the same.
Can you explain this further:
What staff? Was this a credit the government offered and Toyota didn’t think it was worth it because the warranty would be too long?
izzy
Bay Area
What staff?
That quote was from here:
PRELIMINARY DISCUSSION PAPER –AMENDMENTS TO CALIFORNIA’S LOW-EMISSION VEHICLE REGULATIONS FOR CRITERIA POLLUTANTS – LEV III
Which according to this website, the credit was ultimate adopted:
https://dieselnet.com/standards/us/ld_ca.php
As for the Hybrid battery, 150k mi was mandated by the state of California:
https://ww2.arb.ca.gov/resources/fact-sheets/california-vehicle-and-emissions-warranty-periods
In my opinion, Toyota should warranty the emissions equipment for 150k minimum, cause these cats are gonna be expensive when they go. Being stolen is unlikely.
They could have used the credit and run a less lean tune on the engine or something, or added 5hp 😂 I kid, not sure 5mg/mi NOx ends up being much difference.
Didn't really mean to sidetrack this thread but the tl;dr is:
If Toyota wasn't a greedy corpo they'd recall replace all the transmissions in the TSB VIN range... the emissions stuff above is just further proof they really don't give a fk about you or your vehicle after 60,000 miles (or however long of warranty you paid for).
Agreed.
Lame the battery warranty is by force. I thought it was because they had so much confidence in their hybrid systems.
Yeah - I agree. They know these transmissions, particularly those in the TSB VIN range, are at risk of failure. Their cost analysis says that most will last through the basic warranty and after that they don't care. If they did they would replace them like they are doing with the Tundra engines. I assume they are doing that because they predict it is cheaper than years of replacing those engines as they fail.
When Toyota was a smaller company trying to get established they over engineered and stood behind their products. Now they are the biggest automaker in the world and they can afford to lose some customers when they let them down. You only have to look at the number of major failures their products have today to know that they are not the same company they were 30 years ago.
