Hey guys - I have a Trailhunter and put 17” wheels on it. So far no issues but I’m worried about the recall. Could you tell me how I can check to see if I’ve got an issue with the brake line clearance? I just posted this video about my wheels / tires this morning.
UPDATE: I looked the the rear brake calipers and brake lines closely — they are pretty damn close .. like half an inch for caliper and 1.5 inch for the line. I think this is one of those “watch it carefully” situations and make sure there’s no rubbing. I’m not sure how it would make contact but if you’re off-roading and something pushes that brake line toward the wheel maybe it could. Or if wheel weights shrink that gap and rub the brake lines. So far it looks ok but I’m mildly concerned. Would like to hear y’all’s thoughts on whether I need to revert back to 18s.
Tacorey
Corey
Atlanta, GA
2025 Tacoma TRD Offroad; 2007 Infiniti M35
I just got my 2025 yesterday. I will get some pictures of the new lines after work. I was walking around in my bed last night and there is a popping noise happening when I walk around the mid-back of the bed. Hoping it's just a loose spare tire.
Forest Moon
Michael
MA
2024 OR Supersonic Red MT
Finally got an official notice in the mail yesterday. Nothing new, it just states they are preparing the remedy and we will be notified again when it is ready.
jdjtn
murfreesboro tn
2024 toyota tacoma trd offroad
Toyota is recalling certain 2024 Tacoma 4-wheel drive trucks with 16-inch brakes and 17-inch wheels due to a brake hose issue. The recall affects vehicles in North and South America, as well as other regions.
What's the issue?
  • The rear brake hoses may need to be replaced because they could be defective
What will Toyota do?
  • Toyota dealers will replace the rear brake hoses at no cost to customers
How can I check if my vehicle is affected?
  • You can check if your vehicle is affected by:
    • Visiting Toyota.com/recall
    • Visiting nhtsa.gov/recalls and entering your vehicle's VIN or license plate information
    • Calling Toyota's customer support line at 1-800-331-4331
https://markets.businessinsider.com/news/stocks/toyota-recalls-certain-tacoma-4-wheel-drive-trucks-1034324395#:~:text=Toyota (TM) is conducting a,the recall for the U.S.
Pootklopp
Usa
2024 Bronze Oxide TRD OR
I know this is a bit old, but can anyone take a picture of the updated lines after the recall was completed?
This is stolen from TW, but it's basically the same as what is currently on the truck, just a little shorter (further from the wheel).
2024 Tacoma RECALL for Brake Hose Issue: 2024 Tacoma 4WD 4-wheel drive models w/ 16-inch brakes and 17-inch Toyota wheels 20250701_085049
MJB4450
2025 SR5
I had mine done last Wednesday. Original hose had about 3/4" clearance. New hose has approx. 1 1/2" clearance and the new hose is ribbed.
2024 Tacoma RECALL for Brake Hose Issue: 2024 Tacoma 4WD 4-wheel drive models w/ 16-inch brakes and 17-inch Toyota wheels IMG_0789[1]
2024 Tacoma RECALL for Brake Hose Issue: 2024 Tacoma 4WD 4-wheel drive models w/ 16-inch brakes and 17-inch Toyota wheels IMG_0787[2]
rijc99
Is it just the brake lines? Or are there any other hardware that needs to be replaced? I’d prefer to buy the revised hoses myself and just replace them when I need to do my rear brakes rather than let the dealer handle my truck.
MJB4450
2025 SR5
Just the rubber hoses but it comes as a side specific kit with hardware. If you try to do it yourself you'll void the warranty. Put the following in your search engine for the technical instructions.
RCRIT-25V058-4476.pdf
rijc99
Ah ok. Thanks. My warranty is almost done due to miles anyway. I’ll just wait a little more then tackle this.
