- First Name
- Greg
- Joined
- Jun 26, 2024
- Threads
- 13
- Messages
- 146
- Reaction score
- 161
- Location
- Albuquerque
- Vehicle(s)
- 24 Tacoma TRD Off Road
That's good news. I won't have to postpone my trip the the Dempster Highway for much longer.
Toyota is recalling certain 2024 Tacoma 4-wheel drive trucks with 16-inch brakes and 17-inch wheels due to a brake hose issue. The recall affects vehicles in North and South America, as well as other regions.
What's the issue?
- The rear brake hoses may need to be replaced because they could be defective
What will Toyota do?
- Toyota dealers will replace the rear brake hoses at no cost to customers
How can I check if my vehicle is affected?
- You can check if your vehicle is affected by:
- Visiting Toyota.com/recall
- Visiting nhtsa.gov/recalls and entering your vehicle's VIN or license plate information
- Calling Toyota's customer support line at 1-800-331-4331
https://markets.businessinsider.com/news/stocks/toyota-recalls-certain-tacoma-4-wheel-drive-trucks-1034324395#:~:text=Toyota (TM) is conducting a,the recall for the U.S.
This is stolen from TW, but it's basically the same as what is currently on the truck, just a little shorter (further from the wheel).I know this is a bit old, but can anyone take a picture of the updated lines after the recall was completed?
Just the rubber hoses but it comes as a side specific kit with hardware. If you try to do it yourself you'll void the warranty. Put the following in your search engine for the technical instructions.Is it just the brake lines? Or are there any other hardware that needs to be replaced? I’d prefer to buy the revised hoses myself and just replace them when I need to do my rear brakes rather than let the dealer handle my truck.
Ah ok. Thanks. My warranty is almost done due to miles anyway. I’ll just wait a little more then tackle this.Just the rubber hoses but it comes as a side specific kit with hardware. If you try to do it yourself you'll void the warranty. Put the following in your search engine for the technical instructions.
RCRIT-25V058-4476.pdf
Wow they stuffed yours down against the shield. Mine are still just a loop but shorter as I pictured above in post #53.Sorry pics are not the same angle.
