Best value mid budget shocks
Best value mid-budget shocks
  • Total voters
    45
Keithz24
Georgia
2024 Tacoma Off-Road
Was this the ARB top hat or the Toyota one? Can you send us a picture?
ARB MT64 top hat. The picture above of the integrated top hat is the same shock. You really cant tell there is play in it until it is loaded up by the weight of the truck. How I tell there is play outside of hearing it going down the road is to grab the control arm and pull it towards myself until the truck starts to rock. It will be evident then.
tkrum015
Ted
Olympia
For anyone interested here is the TRD Lift with OME UCAs 🤷🏻‍♂️😜
39 inches in the front, measured from the ground through the center of the hub to the bottom of the fender
40 inches in the rear measures the same way as the front.
You did not want to use the TRD UCA’s. Did you just add the TRD shocks?
tacomedic1847
Nathan
united states
2024 Toyota Tacoma TRD offroad
Finally got the Ironman 4x4 IM2.5 kit installed and it is amazing! Blown away with the ride and control so far, going to a 2.5" shock makes a huge difference.
hows the ride so far on those IM2.5 pretty soft? been able to take them out on a trail?
Alchemy
Shawn
LV
26 4Runner 25 Tacoma
I know nothing about these but five minutes of Googling reviews on them, seems like everyone who has them likes them...
https://www.ironman4x4.com/products...a-tacoma-2024-toy093kp?variant=46331567702251
They are a bit stiff in my opinion. Good but there is better in the same price ranges. Just my .2. Reviews suck its not like people are testing multiple setups. I had the privilege of having a friend get them and I have driven a few Tacoma with different shocks.
ScottyMcfly
Scott
Western Mass
2025 Tacoma
Damn, that looks pretty damn sexy
Congo
Shawn
2025 Tacoma TRD Sport i-FORCE MAX
Yeah did a couple hundred miles offroad, the second weekend of having them, they are amazing. They do break in after a couple of hundred miles. Very soft and compliant but honestly maybe less body roll than stock, they have been amazing for me.
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
I've posted in other threads but this is probably the most relevant. I got the 6112s installed about a month ago and they've been so good. Totally transforms the experience.
2024 Tacoma Best value mid budget shocks IMG_0192
Congo
Shawn
The foam cell is definitely stiffer than the IM2.5's. 2 completely different technologies and setups.
gofastdan
Agreed. I ended up going with the complete foam cell package including UCA's, ECG needle bearing swap, Dr KDDS rear track bar level, new tie rod ends, heavier springs in back, etc... I just got the last of it all installed today (and found that I have a leak at the back of the transmission housing where the driveshaft inserts, so a call to the dealer is in order).
Everyone always wants to talk about how great this or that suspension set up is but few ever discuss their use-case scenario. I really wanted the IM2.5 and the guys at Ironman4x4 talked me out of them. The reason is that I'm fully built out now for overlanding and am carrying a ton of weight (almost literally). I'm not flying across the dunes catching air, I'm crawling through the backwoods trying to find a place to hide from civilization. I need a suspension that is bulletproof and that I don't have to worry about failing at the wrong time. That's what the foam cell shocks promise. Are they the plushest shock around? No, and I'm ok with that. They're built to carry weight across adverse conditions for long distances w/o fade or drama and that counts with me.
I only have a hundred miles or so on them and haven't taken it off road yet, but in the next few weeks I'm driving from Seattle to Phoenix and back and will be getting plenty of miles in off-road and on and will give my impressions.
Use is key.
Congo
Shawn
They should soften up a little, I am mostly stock, don’t plan on adding a ton of weight, so that’s why I went for max comfort. Most I’ll do is add RTT and topper, but then I’ll do the heavy rear springs and call it a day.
