Big Dawgs Toyota Tuning
Quez
Nashville
www.bigdawgstoyotatuning.com
When I posted this initially, I was just getting done with a 2 hour v-band clamp fight.
Hindsight, I realize I didn't give any context about the purpose of this upgrade - or really any info about it. I wanted to come here and give a quick rundown for those who may be unfamiliar.
On the 2024+ Tacoma, the downpipe (DP) is the section in the engine bay that links the turbo to the rest of the exhaust system. From the factory, it’s one of the more restrictive pieces because it houses the catalytic converter (what people mean when they say “cats,” “catted,” or “catless”).
The main reason people swap the DP for something like Overland Tailor Tuning’s (OTT) version - it flows much better than the OEM unit.
Less restriction = better airflow = more power.
Like most manufacturers, Toyota builds the stock downpipe with a focus on keeping things quiet and emissions-compliant. A high-flow catted DP uses larger piping and a more efficient core. In simple terms, that reduces exhaust backpressure and allows gases to move out more quickly.
With less backpressure, the turbo can spool faster, which means reduced turbo lag and improved pedal responsiveness in a wider RPM range.
Pair that with the OTT Stage 1 calibration from Big Dawgs Toyota Tuning, and you’ll notice a solid bump in usable horsepower and torque.
Just to note, a downpipe is more of a supporting mod when you’re power hunting. it’s one part of a larger picture. It can provide gains, but I've yet to dyno test my truck to give exact numbers for this specific dp.
Another big reason people go with a DP is the sound. Everyone wants their truck to have a more aggressive tone. I’ve always joked that overlanders are the modern version of JDM bois, and that still holds true imo. A high-flow catted DP will give you a louder, deeper exhaust note. I’m running a stock TRD Pro exhaust, and it’s noticeable but not over the top.
A high flow catted dp won’t be as loud or obnoxious as going catless, but you’ll definitely hear the difference. I’ll have to get some sound clips together at some point.
You probably noticed I’ve said “high-flow catted” a few times. That part matters for most people (probably 95% or more). A high flow catted DP keeps your emissions system fully in place, which helps cut down on exhaust smell and avoids triggering check engine lights (CEL). So you’re not dealing with strong fumes at stoplights, on the trail, or at your local Cars & Coffee. And of course, it’s the better choice environmentally as well.
Here's a couple quick pics of the OEM downpipe and OTT High Flow Catted Downpipe (@JustDSM) next to each other.
2024 Tacoma OEM downpipe vs. OTT High Flow Catted Down Pipe - side by side comparison DSC01901
2024 Tacoma OEM downpipe vs. OTT High Flow Catted Down Pipe - side by side comparison DSC01905
2024 Tacoma OEM downpipe vs. OTT High Flow Catted Down Pipe - side by side comparison DSC01908
2024 Tacoma OEM downpipe vs. OTT High Flow Catted Down Pipe - side by side comparison DSC01907
2024 Tacoma OEM downpipe vs. OTT High Flow Catted Down Pipe - side by side comparison DSC01899
2024 Tacoma OEM downpipe vs. OTT High Flow Catted Down Pipe - side by side comparison DSC01902
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
What sort of gains? I imagine quite good when tuned. Also, at what point are you guys requiring 91+ rather than recommending it? I would assume once you do this?
Quez
Nashville
I haven't had the truck on a dyno yet, but will at some point. Will probably have our 4R on there as it's still stock so I'm curious what kind of numbers that will put out.
Quez
Nashville
Where are all the tabs, or are those for the stock heat shields? All the sudden they are not needed anymore?
The stock heat shield isn't needed for this DP. If you want the extra heat reduction, there is an optional upgraded insulated stainless thermal shield you can request.
TimC.
Tim
Ridgeway, VA
2024 Toyota Tacoma
I have a question. How robust is the flex joint in the pipe? Is there a concern that this area will separate over time with heat cool cycling? This is a really nice upgrade.
tipsyjam
Hawai'i
Sup Big Dawg got some questions, does the oem exhaust front pipe connect to the new downpipe using the same donut style gasket like it does from the factory, or is it a different style gasket? I see the donut gasket still on the outlet of your old downpipe in the picture. I was curious how your exhaust bolted up to the new downpipe as there doesnt seem to be a lip for the donut gasket to sit on the aft side of the downpipe outlet flange.
I dont see welded nuts on the forward side of the outlet flange of the new downpipe, so is it the oem spring bolts going from the aft side of the front exhaust pipe flange into new nuts on the forward side of the downpipe outlet flange, or is it different fasteners that are used? If not spring bolts, is there any effort made to stop the fasteners from vibrating loose such as a spring lockwasher + washer combo?
How does the downpipe connect to the turbo? Is it still with the band clamp and knock pin like oem? I see a hole on the turbo side flange that looks like the knock pin hole but wanted to confirm as the flange shapes are different between the two.
Were you provided instructions from OTT for install and final torques, or were you able to pretty much stick to the repair manual procedure from TIS and just perform applicable steps as you go? For example, the new downpipe doesnt have a stay bracket to bolt to the engine/transmission so you would just skip that step.
TacoKiwi
Barry
2008 Jeep, 2014 Q5 TDI
Downpipes make the driver feel good unless a corresponding tune is installed. Same with $$ for exhaust and for intake filters and airboxes. IE you have to void your warranty to take advantage of these mods. The only way to get warrantied power is to always travel downhill.
JustDSM
Justin
Ogden, UT
www.overlandtailor.com
2024 Tacoma TRD Offroad
Not to step on @Big Dawgs Toyota Tuning 's toes, but I can answer some of these questions for ya!
Our downpipe has a custom V-Band flange with a locating hole for the alignment dowel on the turbine housing outlet flange. This helps ensure proper orientation and alignment during installation. The V-Band flange we use also allows us to retain the OE V-Band.
At the other end of the downpipe, where it meets with the exhaust mid-pipe, we have a custom flange which eliminates the need for the OE doughnut gasket, allowing us a full 3" outlet at the rear of the downpipe. This custom flange will mate to a OE mid-pipe or aftermarket one such as the AWE using a custom gasket we supply with our downpipe. We also supply hardware that eliminates the OE fasteners and springs, so you can securely fasten the mid-pipe of your choosing to our downpipe. Should you wish to make a custom exhaust, we can also supply a custom flange that will match our downpipe, allowing you to create a full 3" system if desired.
As for retention, we've not had any issues, as the addition of the flex coupler in our downpipe isolates the rear flange. When properly torqued (we provide the hardware and torque specs), you should not run into any issues.
Installation instructions are provided.
Quez
Nashville
I have zero concerns on this. The quality is great.
Quez
Nashville
Dude, I tuned my vehicle with 11 miles on it in the dealers parking lot, I also installed an upgraded turbo with less than 10k miles on it. I am not concerned in any form or fashion with what the dealer has to say about my truck or what they think they can deny for my warranty.
Quez
Nashville
Yeah, what he said. Package came complete with instructions, torque specs, upgraded hardware, and a gasket.
The best part was the envelope that said, "parts inside, don't bend." Lol
