2024 Tacoma Transmission Overheating on Long Climbs Off-Road
Anamouse
Ana
Los Angeles CA
2025 4WD 4 door long bed Tacoma Off Road
Are you using S mode and downshifting uphill or leaving the truck in D?
Gotta downshift going uphill to force the converter to lockup and the closer you are to the engines peak power, the less work the torque converter has to do.
These are small engines, you're gonna hear it when going uphill at low speeds where you can't utilize the torque.
No, I did not use the S mode. The problem appears to the the torque converter needs a flow of air to keep it cool during steep climbs and if you go slow there isn't enough air flow
Anamouse
Ana
Los Angeles CA
Did they say anything other then we know about it?
Might be the first case I’ve seen where Toyota said anything at all.
No, they didn't say anything other than the factory is aware of the issue and not sure what they want to do.
Someguysomewhere26
united states
2025 tacoma SR5
To be honest I’m not sure what their options would be which sucks.
It’s either a software update to change the way it behaves
Or an added trans cooler. Which I think best case we would get as a tsb or more likely it’s just added to future models :/
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
Just did a few days with an unloaded TRD Pro at 9-11k elevations.
Noticed a few things - in 2Hi in regular drive mode the truck likes to stay under 2k rpm's which caused the tranny to start to overheat.
When I went to S Mode and kept in 2d or 1st gear the temp dropped back down to mid range and stayed there all day.
Its not an airflow issue because no matter what gear I chose the speed and airflow remained the same and only started to overheat when it was in third gear or higher or under 2k rpm. 1st and 2d gear as long as I kept the rpms 2k or higher the tranny temps were stable.
Question now is, is it something with the torque converter that causes it too slip more under 2k rpm, or is it just an engineering/mechanical/gearing problem with 3rd gear or higher.
Anamouse
Ana
Los Angeles CA
Wait, what? No transmission cooler? Do any of the models have one, the ones with the built in trailer brake controller perhaps?
The transmission line runs through the bottom of the radiator which is supposed to keep it cool. I got the towing and offroad packages and there was no transmission cooler option I could purchase.
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
Wouldn't a cooler be subject to airflow? It's not an airflow issue.
A cooler couldn't hurt right, but that's not the issue with our tranny's overheating.
Will721
Will
Quad Cities
2025 TRD OR
The only difference to the transmission itself 4hi-4lo is overall rpm. Same can be said in lower gears. The higher the rpm at the input shaft, the higher volume fluid the pumps gonna push. The transmission can regulate itself using solenoids for pressure, but not volume of flow. Also, the mo
If that is the case, the only option would be a larger cooler, possibly with more air flow. While you can't change the volume of fluid flow without changing driving habits, you could reduce the temperature of what fluid it does get as much as possible to therefore reduce the overall average.
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
that makes most sense Will721
24 TRD OR
Greg
Albuquerque
24 Tacoma TRD Off Road
I have the Mishimoto trans cooler and it works great. Hills that I climbed before that would cause my truck to stop due to the transmission overheating, I can now climb without stopping. I left a review on my YouTube channel "Great Overland Experiences". But for those who aren't interested, suffice it to say, it works as advertised and really helps. Than you Mishimoto!!!!
Gfenza89
Gary
2022 tacoma sr5
Toyota doing nothing as usual to figure out a serious problem
