Fluids for 6MT Drivetrain
AmbyBomb
Nick
2026 Tacoma TRD Sport
BLtheP
TX
I think my transmission shifts better with Driven 80W-90 GL4. My favorite manual trans fluid I’ve tried across all my vehicles.
co425
Brandon
BMW Motorcycle
Never mind saw 6mt in the title.
Which transmission is the spec listed for above?
AmbyBomb
Nick
I assume the 6 speed manual transmission.
Sandeep1994
Sidhu
I used redline Mt . Transmission started shifter quicker and smoother also 1-2 gear clunk is gone
AutomatedUser
Casey
Sioux Falls, SD
26 taco, 93 and 94 mr2's
In all my vehicles i run Amsoil fluids, but the exception is the MTF (and brake fluid, dot 5.1 FTW), I tried it in my mr2 but swapped it out immediately as it seemed to grind more often, this was on a pretty worn e153. MT90 is fantastic, redline 75w85 with a pint of LWSP is better, the ford magic gl4 transmission juice is even better but at well over 30$ a quart it's a big ask even for me.
BLtheP
TX
I think I’m the only person on the planet that didn’t like the Ford stuff at all. Everybody else raves about it, I did not like it. I’ve tried it, MT-90, stuff from Sta-Lube, Ravenol, and Driven. And Amsoil in a friend’s truck. Driven beats every one of them for me and it’s like $15 a quart at Summit.
My specific experience finds that conventional = better, synthetic = worse.
24tacoman
2024 TRD OR 6M
MT90 every 30k miles (50k km) and you won't go wrong. Use whatever 75w90 is cheapest for the diffs. Transfer case uses Redline MT-LV.
AmbyBomb
Nick
I'm only at 5,000 km (so 3,000 miles) but with all the threads showing shavings in the trans or diff fluid, I'm going to replace mine earlier, say at 10,000 km.
