- First Name
- Will
- Joined
- Nov 19, 2025
- Threads
- 3
- Messages
- 432
- Reaction score
- 497
- Location
- Quad Cities
- Vehicle(s)
- 2025 TRD OR
If someone had a diagram of the charging circuit I can tell you if the alternator charges the battery. I would assume that it does because the battery is also the "equalizer" in a charging system. It absorbs voltage spikes and protects sensitive electronics.
It used to be a common test for the altenator to disconnect the battery while running to see if the alternator is bad. It has since been discouraged due to the addition of complex electrics.
