12V battery problems 24 TrailHunter
Will721
Will
Quad Cities
2025 TRD OR
If someone had a diagram of the charging circuit I can tell you if the alternator charges the battery. I would assume that it does because the battery is also the "equalizer" in a charging system. It absorbs voltage spikes and protects sensitive electronics.
It used to be a common test for the altenator to disconnect the battery while running to see if the alternator is bad. It has since been discouraged due to the addition of complex electrics.
MustardTiger
TacoMAX/SDuty/Dmax
My truck had the original battery replaced before I bought it (new). Dealer never said anything about it during the sale. I assume it was low SOC during transport and froze.
Whenever I test the battery with a test monitor, it always says “Battery good, recharge”. SOH is about 91%. Voltage usually 12.1-12.2v. I installed one of these chargers, and will plug it in if the truck sits for more than a week. Just another rinky dink task that’s part of owning this truck I guess….to overcome Toyota’s recurring stupidity.
2024 Tacoma 12V battery problems 24 TrailHunter IMG_1236
Noco 2D
I don't know if this is true, but charts I have seen say that a 12 volt is only 50% charged at 12.2 volts, which is what mine often is.
MustardTiger
TacoMAX/SDuty/Dmax
Confirmed with Carista, while driving. Spends majority of the time at 12.8v...
In my experience, vehicles with a traditional alternator will keep the battery at 14v +...or 13.8v. Never 12.8v. That would indicate your charging system isn't working. So, having said that...this is an extremely weird charging system logic that toyota has programmed in these hybrid trucks. No wonder the batteries fail.
2024 Tacoma 12V battery problems 24 TrailHunter IMG_1248 Medium
2024 Tacoma 12V battery problems 24 TrailHunter IMG_1246 Medium
Yes, strange charging system in the hybrids. My truck jumps from its resting SOC to the low 14V range when I first start it. Then it fairly quickly drops down 12.8V and mostly stays there, so it is not a surprise that hybrid 12V batteries have short lives. I guess as long as they last for the 24 month warranty Toyota doesn't care.
When I complained at my dealer, a lady with a good solid couple months of service advisor experience told me I don't drive it enough. I said even after driving it all day it is still not fully charged, which tells me the charging system is inadequate. She then told me I needed a trickle charger, and I have never gone back. I don't have to drive an hour to get lied to by some fat chick who has no clue about automotive electrical systems. Bottom line, neither the dealers nor Toyota give a crap and we are on our own.
I just gave up and I put a trickle charger on it every week or two and now its resting SOC is usually between 12.3V-12.5V, so maybe 70-80% charged. That is better than what it can do on its own, but it is never fully charged unless I leave it on my maintainer whenever I'm not driving it. It looks like it is working as designed to me, but it is just a crap design.
shackley
www.swxrflab.net
I doubt that Toyota will do anything about this until it effects their bottom line, and given the sales numbers isn't likely to happen anytime soon. I have a 26 TH, and put a charger on the 12V at times when I'm not driving much (I'm retired).
Kodachrome
I wouldn't call it a quality hit, thats not exactly the issue. It all comes down to government over regulation that has caused all these issues. Junk CVTs are due to overwhelming fuel economy regulations. The domestics eating their valvetrain is due to emissions. Diesels are having issues with dpf and egr from emissions. Low tension ring issues are from fuel economy. We don't even get some of the best, and well designed engine options available due to emissions. These charging system issues are likely due to Toyota chasing economy numbers by reducing overall engine load. All of it comes down to three groups pushing and pulling manufacturers to get what they want.
The NHTSA wants safer cars. The best way to do that is to add more material for larger crumple zones. This makes cars bigger and heavier. Meanwhile the EPA wants fuel economy and emissions. Heavy cars aren't good for economy so manufacturers have to shave weight wherever they can which is why we see so much plastic where it doesn't belong. Not to mention overly complex vehicle controls, emissions equipment, low friction cylinde linings (that fail), transmissions with way mor gears, auto start stop, and smaller displacement with turbos.
Meanwhile the consumer doesn't care for most of that. They want a relatively safe car thats decent on gas but want as much horsepower as they can. Not to go fast, but to get that bloated heavy hunk of metal up to speed on the highway comfortably. But horsepower isn't good for fuel economy or emissions. But the nhtsa makes sure you need more of it year after year. To put it in perspective, a 4th gen Tacoma (Midsize truck) weighs more than this by 200lbs:
At the end of the day, this is an America problem. Manufacturers have run out of options. They are being pulled in every direction with no end in site. Its why every manufacturer was pushing so hard into EVs, they are easier to meet regulations. But the consumer didn't want them. They have too many drawbacks. Which is why so many are now doubling back.
Yeah, well...that is pretty dismissive of the reality we are in on a global scale.
My other car is our second leased Audi EV and with our solar, home battery packs, etc we are practically on a closed loop system of renewables, range is more than fine. So I would maybe *not* use blanket statements like "But the consumer didn't want them" because it sure as heck does not apply to everyone. Other countries are doing very well in this regard and yet are still going to suffer the consequences of other selfish countries bad habits and cult-like behavior.
But here is the deal, the near and far future ecology is done cashing the bad checks that the past and present seem hell bent on writing. Full stop. From this point forward, everything is going to continue to cost more out of pocket and the things that were had cheaply will cost us in other ways.
In just ten years, I went from advocating policy changes in carbon reduction using studies and think tanks to scrambling to what is now the area of greatest need and that is infrastructural innovation and adaptation strategies.
You can thank me later when it finally becomes crystal clear to you just how late we are in growing and showing up.
As for the topic, I will keep an eye out for battery level with my iDash gauge. I live near a ski area and the truck is outside full time, so it might get interesting if we get lucky enough to have what was once a normal Winter ever again...
No, I don't expect Toyota to do anything, particularly since my wife's battery electric and a friend's plugin hybrid have the same issue. I love my truck and charge if when I have to, but this should be Toyota's problem and not ours.
Kodachrome
Just drove 30 minutes stoplight / highway mix and 30 back. Voltage was 13.9-14.2v going up, steady 14.2v going back, 2026 Trailhunter 1,082 total miles.
MustardTiger
TacoMAX/SDuty/Dmax
You would have an alternator on yours, being a 2026. So maybe it does make a difference, and charges “normally”
A different though, if OTT coded their hybrid tune to fix the charging logic…I’d be interested
JustDSM
Justin
Ogden, UT
www.overlandtailor.com
2024 Tacoma TRD Offroad
We offer AGM specific charging profiles (for 14.4v-14.7v depending on temperature) on a as requested basis. The increase is not part of our standard calibration offering.
It's a no-cost option, but must be requested.
Kodachrome
Do you know offhand what the standard charging profile would be? Specifically any hybrid 2025+ that is known to have an alternator, in my case a 2026 Trailhunter.
JustDSM
Justin
Ogden, UT
They use the same charging profile as the 3rd Generation Tacoma trucks, which came with a traditional lead-acid battery, oddly enough.
TFOUTS
Timothy
Northwest Florida
Optima Yellowtop DH7, rated to 880 cca, pic attached.
We are planning to visit Shale Oak Winery — will ask them as the time draws near, to confirm that our dog is welcome to accompany us. Late Sept. timeframe.
My OEM auxiliary battery went dead 90 miles from home Friday night, not sure how or why. Was parked most of the day in a remote area of northwest Florida. On the first try to push button start, no response, but display was blinking with all kinds of error messages, as if it was gasping for power, but no ignition response. Tried jump start with my Zeus Pro, no response or spark. Eventually everything was completely dead, no tones, mileage on screen, nothing. Found a towing company to haul it to Pensacola dealer 95 miles away. They delivered it 10 am Saturday morning, it was ready for pickup 1:30 pm. Needed new battery but they put in the Toyota Genuine #00544-H6074-770 Toyota TrueStart Battery, Group H6 (LN3) - 84 Month Warranty
This is not the same battery from the factory that went discharged. I was looking for the Optima deep cycle so I could install the Lensun 110W Hood Flexible Solar Panel (complete kit (solar panel+MPPT solar controller+vinyl decal) that I recently purchased. My local dealer suggested I not install the solar panel until after the powertrain warranty expires which is at 60k. That is ok as I purchased an extended warranty from Toyota until 120k. Am currently at 42k. My original Alabama dealer said they will install the panels and the Optima battery for minimal costs as they have performed other upgrades for me as well. The owner has a Tundra TRD PRO Performance package with CBI covert bumper w/ winch, and other roof rack and bed rack stuff. He also has a new lifted Sequoia Capstone. Very off road friendly. After all, this is Talladega County.
In summary, a better battery installed, will monitor how it goes, and report back if anything comes up.
shackley
www.swxrflab.net
I plan to go Optima in my 26 TH as well. I keep it charged when it sits more than a day. I'm not sure, though, that the Optima will last much longer, but geez does Toyota buy the cheapest batteries they can find like their tires? I'm a geologist, I don't want to get stranded in the middle of nowhere...
