I need help choosing an air compressor
tacochoco
Ricardo
Phoenix
2026 Tacoma TRD off road premium
I am considering an air compressor for my rig, choosing between the OEM unit included with the Trailhunter and the CAtuned Off-Road ARB Twin Air Compressor Rear Bed Mount.
Pros for each: the OEM unit offers digital PSI control. The CAtuned ARB twin air compressor avoids bed cutting and provides much higher airflow.
The OEM unit has drawbacks because it requires cutting the bed. For the ARB twin air compressor, I must run wiring from the bed to the battery at the front.
PNKTACO
2024 Tacoma Sport
Also have to factor in that the OEM air compressor, as cool as it is, is $1500.
tacochoco
tacochoco
Ricardo
Phoenix
I mean to be honest with Black Friday sales they both come out to the same amount.
Cappaworks
2026 Tacoma TRD Off Road
Unless you are in a really big hurry to air up your tires, the Twin Air is way excessive for tires that are smaller than 37s or so. For a 285-70R17 the singe motor is plenty. It’s also more compact and fits into tighter spaces. I prefer the portable version for use on multiple 4x4s, but I understand that some people don’t want to give up the space it requires.
A wiring option to consider is making use of the power wire on the trailer plug. On a Tacoma, it’s only energized when the key is on, but I have successfully used a custom trailer pigtail to operate a fuel transfer pump from my trailer plug. The same could be done with a compressor I imagine, although a Twin Air might pull too many amps for that system.
Okiefisherman
Oklahoma
2025 Tacoma TRD Offroad
I’ve bought 2 12v compressors both are loud and bulky. My favorite by far is the 18v Milwaukee- just works faster and quieter and doesn’t use hardly any battery to air up 4 tires. I bring it on trips now instead of the 12v units
bsquaredMTB
Ben
El Paso, TX
I purchased this one on sale and it works just fine from my needs. I don't air down super often but when I've needed to (or when I got a flat) it was ready to go. Sometimes (and this includes me, personally), we get caught up in the best and most expensive, but there are plenty of products out there that are cheaper and work well enough for specific needs.
Okiefisherman
Oklahoma
I agree, and the Milwaukee is cheaper-
As long as you already use their system and have batteries.
Rubenc87
Ruben
2025 TRD PRO
Really depends on budget/no budget? Installation location? Under the hood or in the bed area. Open the hood every time to use? I saw the CATuned in bed version but opted for my own version. I used the same location as the Trail Hunter location and didn't make the huge cutout. Four holes to hold ARB Vs the TH cutout. Ready to use as soon as I press the AUX 3 switch. More power than the OEM.
2024 Tacoma I need help choosing an air compressor IMG_4851
2024 Tacoma I need help choosing an air compressor IMG_4835
Gearman
Kris
Utah
2019 F350 Platnum, 2025 Tacoma OffRoad Premium
I used the Milwaukee 18v unit last year..... found it works but painfully slow.
we did the White rim trial in Moab couple weeks ago and other trails and wanted a faster option to air up tires. We got the Wolfbox portable unit. (approx $300 for a digital readout, portable dual compressor)
It's fast, accurate and easily aired up 3 vehicles at the end of the trail. Recommend you take a look at this option.
originally I wanted to mount the Trailhunter Toyota model in the bed, then saw the price.
Looked at ARB options..... was about to pull the trigger then saw that Wolf box just started selling there options and someone posted Wolfbox SEMA show booth with all they had, went to there website and had within a few days. Considered permanent mount, but I have 2 trucks, portable made more sense for me to throw in what ever for the trip.
bought the Huskey 5gal dustproof storage box and fits (tight fit with extra long hose). which is perfect for my set up and can easily be thrown in any truck/Jeep we decide to travel/camp in.
All I can say, what an upgrade from the Milwaukee and Dewalt portable air compressors.
Wolfbox link to amazon ($284)
2024 Tacoma I need help choosing an air compressor Image 11-21-26 at 8.04 AM
2024 Tacoma I need help choosing an air compressor IMG_0767
djevans
Don
Tennessee
2025 Tacoma
I'm virtually positive this isn't what you have in mind, but I already had this and it has worked and worked out perfectly for us. It's also automatic, in that, when it reaches it's set pressure, (you dial the intended pressure) It just cut's off. Again, it's been perfect if all you need it for is tire inflation. https://www.amazon.com/Ridgid-18-Volt-Digital-Universal-Inflator/dp/B091MCVWT7?tag=ustxtaddt-20 (you also don't have to hold it on the valve stem - it locks on) note: the link is just an example - the whole kit is still cheaper at HDhttps://www.homedepot.com/p/RIDGID-18V-Cordless-Portable-Inflator-Kit-with-2-0-Ah-Battery-and-Charger-R87044K/314026557 interested - https://www.homedepot.com/p/RIDGID-...-2-0-Ah-Battery-and-Charger-R87044K/314026557
GR8Santini
TX
‘26 Land Cruiser, ‘25 Tundra TRD OR, ‘26 Tundra Hybrid LTD TRD, ‘97 F250HD 7.3L
