2026 TRDOR Premium didn't come with Key Card
Filgr8
Ontario, Canada
2025 Tacoma TRD Off Road
Check again, there’s a secret key in the keycard as well.
He mentioned that "2) If the battery in the key card goes bad, you can't open the the door, on the fob there is a secret key that slides out and you use that to open the door."
FinallyErik
IL
2024 SR5 DCSB 4x4
Read it again.
If the battery in the keycard dies there is in fact a key in the keycard. He’s referring to the key in the fob
Filgr8
Ontario, Canada
Read it again.
key in the fob is obvious (i guess it's obvious) therefore thought he is referring to the card key blade. Anyway I like having no keys, just wallet :)
Wife bought my 24 TRD
Anthony
Aberdeen Wa
Two hundred and fifty dollars is a lot easier to replace than an eight hundred dollar fob.If you lose it, food for thought.
At my local dealership? They pull the key card and use it to drive the vehicles. That's typically while they're not in the truck?
It's for me, it's worth it, because I always have my wallet on me. The truck locks after it's parked, and I don't want to carry around my keys or fob.
shackley
www.swxrflab.net
Just picked up my new 2026 TRDOR in Heritage Blue this last Saturday and I looked everywhere and could not find a key card. I asked the dealer about it and they said they don't all come with them. If it did, it would be on the window sticker or listed on the VIN breakout. I didn't see anything like that listed, so I'm assuming it just didn't come with one.
Is it worth the $250?
My 2026 Trailhunter came with the key card, but it's not listed on the window sticker. I don't use it, but kept it in my wallet. I use the key fob since it has my other keys on it. You can't do that with a key card. However, if it's in your wallet, you don't have to worry about brining your keys from the house. I can't see it being worth more than 200 bucks though.
shackley
www.swxrflab.net
Last One
Larry
WNY
2014 Tacoma
My SR came with the key card, Yours should have come with it.
Miqie
2024 TRD Sport-Bronze oxide.
My 2024 Sport came with a key card. There was nothing on the window sticker about it. I use it all the time, in fact I've had to replace the battery already.
JoeMongo
Jonathan
SF Bay Area
2024 TRD Offroad, Premium, MT
Yeah, it's worth it, but your truck came with it.
j.
Mrt858
RI
2025 Tacoma sport
I have a Limited that came with the key card. I keep it in my wallet since it's the size of credit card. Don't carry any keys anymore, my house door is touch code no key there either. There is 2 things different from fob to key card: 1) you can't remote start from the key card 2) If the battery in the key card goes bad, you can't open the the door, on the fob there is a secret key that slides out and you use that to open the door. I also downloaded the virtual key to the Toyo phone application as a backup. Sometimes if I'm outside without my wallet and I can use my phone to open the door and start the truck (starting the truck from the phone is tricky and takes a few attempts to get to start).
There is a slide out physical key in the card you can open and unlock the door with
gfk
2026 hybrid ORP
I saw this thread the other day, and am currently purchasing an OR Premium... i noticed that it says its "key card compatible" but doesn't say anything about whether or not i actually get one. I'm not too worried about it personally but wanted to add that I saw that note as OP figures out what to do.
KDubZ
Kody
Hawaii
25 Tacoma TRD Off Road Premium, 19 4Runner SR5
In Hawaii, the SR5 Upgrade Package, TRD Sport and Off-Road Upgrade and Premium Packages, Limited, TrailHunter, and TRD Pro come with the key cards.
Leucosia
San Diego
2025 Trailhunter
I have one of those credit card holder type wallets where you can "eject" the credit cards out, like a code knockoff from amazon. It also has an elastic band on the outside. I keep the keycard by itself flat on one side held by the elastic band.
this also makes it so the sensitivity is low as the main body of the wallet is RFID blocking. If that layer is between me and the car, it wont detect it and i sometimes have to turn my leg toward the door.
I prefer this setup to the keyfobs. I don't know if i would pay 250 for it though. The keyfobs sit in a faraday box in my document safe.
