saerandy
Randy
Virginia
2024 SR5
The Oil Geek changed his transmission fluid and gear oil and ran analysis at 5000 miles. What's interesting is are the wear metal levels in the fluid in case you've ever wondered about what's going on in there until you change. I had planned on changing it early - but not that early - but it's interesting (not surprising) to see just how much is in there. He discusses those levels in the video too.
saerandy
Randy
Virginia
2024 SR5
Hmmm...the 0w20 sheared out of grade...? What have we been shouting from the roof tops, but nobody listens. My bet is that mr speed will be putting 5w30 in his Tacoma post 10k miles.
He said he'd be doing a video on this at some point I believe, but he definitely mentions it. I just did mine - Oil at 4400mi and engine @24,000mi on TGMO and it's still in grade for me:
2024 Tacoma New Motor Oil Geek: Transmission and Gear Oil Analysis at 5000 miles on Tacoma Screenshot 2026-05-02 at 2.53.26 PM
MustardTiger
TacoMAX/SDuty/Dmax
@saerandy shouldn't your 100c viscosity be at least over 8 cst to be in grade for 0w20? At least your fuel dilution is under 1 (% I'm assuming).
BLtheP
TX
Not surprised at all. Careful though, I’m sure Mr Dennis d will be running along at any minute to tell you how you can’t prove anything else is better.
DENNISD
Dennis
Omaha
Thanks for the invite.......:wink:
I watched the video Toyota vs. The Motor Oil Geek - Let The DATA Decide!, and it pretty much reinforces what I’ve been saying all along.
The entire point of that discussion is simple: let the data decide — not opinions, not assumptions, not “what feels safer.”
Toyota didn’t just randomly land on 0W-20 and 10k intervals. That’s based on:
durability testing
wear analysis
fuel economy requirements
long-term validation across thousands of engines
If someone wants to run a thicker oil or shorten intervals, that’s fine — but the burden of proof flips at that point.
You don’t have to prove the factory recommendation works.
That’s already been done.
You do have to prove your change is better.
And not with:
“I feel better running it”
“It seems quieter”
“I’ve always done it this way”
But with actual controlled, comparable data:
same engine
same driving conditions
same intervals
repeated UOAs showing a clear improvement
Otherwise, you’re not improving anything — you’re just changing variables and calling it an upgrade.
The video makes that very clear. When you actually look at the data instead of the noise, the argument usually gets a lot quieter.
When the data runs out, the opinions show up.
BLtheP
TX
durability testing
wear analysis
And not with:
“It seems quieter”
same engine
same intervals
Except usually you reject data.
durability testing
wear analysis
And not with:
“It seems quieter”
same engine
same intervals
I thought last time it was the memes that show up?
saerandy
Randy
Virginia
2024 SR5
According to SAE J300 *new* 0W-20 oil must be between 5.6 and 9.3 cSt at 100C to be in spec so at 6.8 after 4400mi it still is in spec. I do a lot of highway miles bit my city/highway split is likely 60/40 which may account for my numbers.
saerandy
Randy
Virginia
2024 SR5
durability testing
wear analysis
And not with:
“It seems quieter”
same engine
same intervals
I agree; Toyota’s 10,000-mile interval is backed by exhaustive validation to ensure these engines reliably reach a 200,000-mile useful life. While UOAs showing dilution & sheared oil may be startling, the data suggests the engine probably still remains within Toyota's engineered safety margins to get it to 150-200K. Owners aiming for 500,000 miles or more can do what they want -- frequent oil changes and UOAs are a logical data-driven strategy -- to exceed base longevity expectations & design. To each his (and her) own, I say!
CharlieLed
Chucki
TN
2025 Tacoma
I too saw the Motor Oil Geek video where he addressed the trans and rearend lubricants...makes sense to me and will definitely impact my decision on when to change out those fluids.
saerandy
Randy
Virginia
2024 SR5
When I saw the UOA’s for both the transmission and differential fluid and the amount of wear particles in there, I decided to do mine today. I originally was gonna do it around 30,000 miles but I’ve got some time today so why not?
