275/70R18 KO3's do NOT fit on a 2024 Trailhunter with Canadian mudflats
scythanith
Scott
Saskatchewan
Just throwing this out there. Just went to replace my 265/70R18 factory tires with 275/70R18 KO3's and they rub heavily on the mud flaps through turns. Tire shop was decent enough to let me downsize after they had installed them on the truck. Going back to the factory size in the KO3's.
Not at all what I remember reading on the forum.
stuckinsocal
24 TRD OR 6MT
What wheel are you running? Offset matters too; if you have wheels that have less offset than the +55mm offset you run the risk of rubbing as well.
SnowmanJPS
Halifax, NS
2025 TRD Pro
My TRD Pro rubbed with the stock tires off the lot. Changed them as soon as I got home.
TacoBirdinNW
2025 DCLB SR5
That size tire fits fine, even on a stock SR5. Could've just got some different flaps.
Tufskinz. Ark. Rokblokz. Rekgen.
Ran that size stock +25 and running that size now with 1.5" lift on +40.
scythanith
scythanith
Scott
Saskatchewan
Factory bronze Trailhunter wheels.
Not worth it at this point. Just wanted replacement without displacing any parts. Just letting others know, I’m not salty about it :)
TacoBirdinNW
2025 DCLB SR5
Totally get it! I was just mostly saying for folks reading this in the future. I ran that same wheel with 275/70r18 on stock SR5 suspension which is even lower than yours. No rubbing, no problems.
2024 Tacoma 275/70R18 KO3's do NOT fit on a 2024 Trailhunter with Canadian mudflats PXL_20260103_190041095
2024 Tacoma 275/70R18 KO3's do NOT fit on a 2024 Trailhunter with Canadian mudflats PXL_20260112_212255949~2
rijc99
275 fit ok but only after I changed the caster a little. It was rubbing here. Still haven’t been able to locate the part number for the little piece yet.
2024 Tacoma 275/70R18 KO3's do NOT fit on a 2024 Trailhunter with Canadian mudflats IMG_6252
Will721
Will
Quad Cities
2025 TRD OR
Don't have a part number for it, but thats the crash brace cover. Pull those two pins and there's a big chunk of steel behind it that unbolts. Ark also makes a cover for when people remove the brace so there isn't a gaping hole there afterwards.
stuckinsocal
24 TRD OR 6MT
Ah ya, those are something like +20 or 25, significantly more poke (and as such more scrub radius and more likely to rub on mud flaps).
nielsd
Niels
2025 Toyota Tacoma TRD Pro
I just replaced the stock tires on my TRD Pro with 265/70 R18 K03s in D load rating. I think it looks a lot better than the stock Goodyear Wranglers. As an added benefit my MPG has improved slightly. Most people go with wider tires but I didn't want that.
2024 Tacoma 275/70R18 KO3's do NOT fit on a 2024 Trailhunter with Canadian mudflats 20260706_110523
scythanith
scythanith
Scott
Saskatchewan
Looks great! I’d welcome the added fuel economy but the 10-ply are pretty heavy. Not holding my breath :)
nielsd
Niels
Mine are 8 ply. So that helped a little. Nice to see another Saskatchewan owner in here. I'm in S'toon.
jetengr19
Oklahoma City
2025 Tacoma Trailhunter
[/QUOTE
Did you upgrade your spare also? I’m curious if the BFG will fit.
