Belt chirp when a/c turns on
UndergorundTaco892
DEREK
New York
2024 Tacoma TRD Offroad
Of course every time I try to take a video, it doesn't happen. I was thinking the same thing with the a/c clutch. I'm going to try and get it in to the dealer soon. I'll report back with their findings.
Any update?
MattAttack
Matt
Boynton Beach, FL
Took it to the dealer on Tuesday. They had it for a day and said it was normal compared to one they had on the lot.
Supertech1
Arkansas
2024 Tacoma TRD ORP
Have you had it looked at?
Not yet. I’ll mention it to service advisor on a future trip. Unless it’s a major issue, I try to address the little issues at the same time as the free Toyota maintenance visits.
I’m not saying the sound is normal, but I believe it’s very common with these trucks.
Kjc
Anc
2024 Tacoma OR
I've just been getting 2 quick chirps right when the truck starts with the AC on....So do they all do this and some people don't notice?
jdmz
Denver, CO
I have the noise as well, and rattle when engine is light load/low RPM. Pretty common it looks like.
Only time will tell if it's a real issue lol.
Supertech1
Arkansas
2024 Tacoma TRD ORP
Want to add to the conversation…
No chirp when starting the TRD Pro. The Hybrid TRD Pro AC compressor does not cycle on and off like the TRD OR iForce engine.
Decided to check the air temp exiting the vents on both the Hybrid Pro and TRD OR iForce, @ LO setting. The TRD OR would fluctuate with the compressor cycle, kicking on at 43 degrees and off at 41.7 degrees. The Hybrid TRD Pro held constant low temperature of 40.6 degrees, did not cycle on/off.
Not sure what this tells us, other than the Hybrid functions differently maybe?
Burgi
NC
24 Taco
Mine also makes the chirp after the truck has been sitting for a while
Jabstep
Southern USA
I have a 2024 Limited non-hybrid and it does the same thing. 2 chirps on a cold start, nothing once its warmed up.
Mitch33
‘24 Tacoma OR
Same noise and vibration here with the OR on startup and when engaging the A/C after it's been off. Doesn't seem like anything concerning, but time will tell.
sparkytaco
Jeremy
2024 Tacoma Off-Road
Searched the forums for this exact reason! Mine chirps twice on startup here in Florida when sitting for a bit :) It sounded like it was the AC clutch. Prob normal then and not a one off situation given the number of people reporting it.
OldOre
AC
TEXAS
2024 TRD OffRoad
Having the same chirp. Doesn't sound like something that an engineer would accept as "normal", but as long as the transmission doesn't blow up, I'll live with it until my 10K service.
