Cobb Tuning has launched support for Tacoma (4th gen) and 4Runner (6th gen)
CAMTuning
CAMTuning
Cameron
New Mexico
2025 Tacoma TRD OffRoad
So now I'm curious what the limiting factor is... Boost or fuel... 🤔
Being that the trucks have port and direct injection, it will be easy to upgrade the port injectors, so fuel won't be a concern. The intercooler needs upgraded, even on the stock turbo. Ethanol blend is going to show a huge gain, and I plan to do some of that tuning this week on my personal truck.
Drifte
Colton
Iowa
24 tacoma trd offroad
This is exciting. Id been missing my turbo cars. I like what Im seeing from both Cobb and OTT. Now I want to share a dyno that will make every tuner squirm. Ive had my fair share of DSMs, subarus, bmws all that I will ofcourse build and tune. This graph is of a stock 04 forester XT with downpipe, and intercooler upgrade. The ecu was locked on this 04 for some reason, so it went back to stock as soon as we saw these AFRs! Id like to add I never lost an engine in my subarus either, fxt, sti.
2024 Tacoma Cobb Tuning has launched support for Tacoma (4th gen) and 4Runner (6th gen) fxt dyno
CAMTuning
CAMTuning
Cameron
New Mexico
I've done literally tens of thousands of Subaru dyno pulls and they all do this on the stock calibrations. The closed loop to open loop delay on the USDM cars is there to lower emissions. If you pull a stock file from a JDM car, the delay is 0.
You're correct that this is no good at all, and a huge reason why a tune is needed after a downpipe because the car will come into boost sooner, and stay lean in boost longer.
Thanks for sharing the graph!
CAMTuning
CAMTuning
Cameron
New Mexico
I want this bad… for a hybrid. It is a nervous consideration though since I got the 100k platinum warranty also.
And I’d probably need some custom tune configs with SXTH intake, SXTH intercooler and AWE exhaust.
While my truck isn't hybrid, the engine calibration portion should not differ. Hybrid support is very near, and highly anticipated!!
Post downpipe exhaust, while it does add a little flow, isn't something that needs to be tuned for until you get into much higher power levels. Most of the restriction is the turbo itself, and the downpipe with catalytic converters.
I will be receiving my own SXTH intake and intercooler in the coming days and will publish those results, and will have a very dialed in custom calibration for those parts that I can offer to customers who also have the intake, intercooler, or both.
Drifte
Colton
Iowa
Post downpipe exhaust, while it does as a little flow, isn't something that needs to be tuned for until you get into much higher power levels. Most of the restriction is the turbo itself, and the downpipe with catalytic converters.
Anxious to hear if the truck is particular about intake and tuning as the old subarus. I hav ethe K&N 63 series that replaces the whole inlet and adds a small airhorn to step down to the compressor inlet. If you havent come across it I put together a little thread here: https://www.tacoma4g.com/forum/thre...-clip-video-on-gas-2024-tacoma-4th-gen.11803/
CAMTuning
CAMTuning
Cameron
New Mexico
Since the truck is open loop in boost, any change to MAF location within the pipe or change to pipe diameter can affect air fuel. I'll be doing some dyno tuning on the SXTH intake in the next week or so and should have some data then. The K&N stuff on Subaru always scaled nearly the same as stock. That intake you have looks nice. Just keep from over oiling the filter so you don't trash your MAF sensor.
CAMTuning
CAMTuning
Cameron
New Mexico
I am excited to announce the official release of CAMTuning's in-house developed Tacoma and 4Runner performance maps. Our dedicated efforts, including extensive dyno testing and real-world road tuning on our development Tacoma have yielded significant enhancements in both power output and overall drivability compared to stock and other off the shelf calibrations. Power delivery, throttle response, and transmission control have all been optimized. Stock vs tuned map.
2024 Tacoma Cobb Tuning has launched support for Tacoma (4th gen) and 4Runner (6th gen) CAMTuning Tacoma
For a limited period, we are offering our CAMTuning Stage 1 map for the Toyota Tacoma for FREE when purchased in conjunction with an Accessport from https://www.camtuningperformance.co...2024-2025-tacoma-stage-1-map-91-93-accessport using code "tacoma4g" at checkout. This map is specifically engineered for vehicles with stock configurations, utilizing either OEM or "OEM-like" intake systems such as those from SXTH, K&N, and Stillen. If your vehicle is equipped with an alternative intake system that necessitates custom tuning, please do not hesitate to contact us, as we are fully equipped to provide such services.
2024 Tacoma Cobb Tuning has launched support for Tacoma (4th gen) and 4Runner (6th gen) dynocli
The Accessport also includes the following off the Shelf Cobb tunes:
ECU MAP OPTIONS:
  • Stage0
  • Stage1 87/91/93 Oct.
  • Performance Tow
TCM MAP OPTIONS:
  • Simulated Stock
  • OEM+
  • Sport
Simulated Stock:This is a stock transmission calibration from a Tacoma/4Runner.
Important notes:
Applications
2024-2025 Tacoma
2025 4Runner
This is for the i-Force engine (gas only), and does not currently support i-Force Max (hybrid)
This is for the Automatic Transmission only, and does not yet support the 6MT.
If you have any questions or just want to discuss tuning, please message me.
CAMTuning
CAMTuning
Cameron
New Mexico
I just came across the video Cobb published a couple of weeks ago. It should answer most questions about what the Accessport is, it's advantages, and how it works.
Drifte
Colton
Iowa
My laptop with Access Tuner pro died a year or so back, and I heard thats no longer available to the general public? Not a deal breaker, but I do like to be able to make adjustments as I go along (If I could leave well enough alone I wouldnt be in here right?).
CAMTuning
CAMTuning
Cameron
New Mexico
ATR for end uses ended several years ago at least, and never existed for Toyota. You wouldn't be able to make adjustments on your own, but if you knew what you wanted changed, someone like me could accommodate. The Tacoma is a completely different tuning strategy vs what you may have seen in Subaru software.
Drifte
Colton
Iowa
I was about to order another scanner just to monitor trans temps and things while pulling the camper and off-road situations. Figured thats $200 right there, so went ahead and ordered the Cobb.
CAMTuning
CAMTuning
Cameron
New Mexico
Working on your order right now! The monitoring capabilities are so helpful on these.
CAMTuning
CAMTuning
Cameron
New Mexico
Spent some time with a manual transmission truck yesterday on the dyno (beta version, still no off the shelf maps, all custom). This was after we did some road tuning on it Friday after I met the owner @Pappy at a local club breakfast. We did 2 pulls on the stock calibration, and the results are plotted below. The truck has some fairly heavy 285/70R17, and I expected it to impact measured WHP, but not as much as it did. The truck also has a lot of additional weight, which makes it feel much more sluggish on the road and off. While baseline was lower than I anticipated, the gains were as good as any of us could hope for. This truck is mechanically OEM, with no performance parts. (@SXTH Element) this guy needs an intake!
At the end of the day I had a lot of fun getting data from a MT truck and meeting an owner who truly uses this truck for overlanding adventures. His excitement driving the truck after the tune is something I wish I could bottle up and share with others!
On to the dyno, of course tuned by me, with Cobb Tuning Protuner Software.
2024 Tacoma Cobb Tuning has launched support for Tacoma (4th gen) and 4Runner (6th gen) 1763477426351-jc
2024 Tacoma Cobb Tuning has launched support for Tacoma (4th gen) and 4Runner (6th gen) 1763477461619-zd
2024 Tacoma Cobb Tuning has launched support for Tacoma (4th gen) and 4Runner (6th gen) 1763477563032-lx
Pappy
Jon
Albuquerque, NM
At the end of the day I had a lot of fun getting data from a MT truck and meeting an owner who truly uses this truck for overlanding adventures. His excitement driving the truck after the tune is something I wish I could bottle up and share with others.
I will admit I'm quite giddy with the tune. The drivability is significantly improved, especially with all the extra weight. Thanks Cameron.
What Cam didn't mention is this was on 91 octane.
2024 Tacoma Cobb Tuning has launched support for Tacoma (4th gen) and 4Runner (6th gen) dyno test-sm
2024 Tacoma Cobb Tuning has launched support for Tacoma (4th gen) and 4Runner (6th gen) dyno test crop-sm
