Id be willing to wager you'd spend more time messing around with the bracket and mounting/remounting than if just did the calibration procedure.Thanks for one of the better explanations. So the answer to my original questions seems to be:
the bracket is required because the OEM bracket is different (flipped) on the Pro/TH for some unknown reason and your OEM won’t fit in the correct orientation.
The calibration seems unavoidable since there are variations such as lift/no-lift and slight variations due to 3D printing
I guess it does raise one more question, can the OEM bracket be drilled to make it fit in its original orientation and thus minimal calibration? I guess I’ll find out when I am staring at it.
Thanks for all the good info.
It seriously takes 3h or less with focus, the space, and having everything on hand that you need at the start.
I and a few others have made some lengthy/detailed posts about it.
Prep/setup = up to 2h
Calibration itself = sub 30min
Clean up = sub 30min
Some have even gambled and just gone to an area with a lot of parking stripe cross hatching, parked at an angle, and used it as a proxy (though I wouldn't advise, bc if you get an out of tolerance error, you'll be forced to do it properly)
