Lennyz1
Len
NY
Not a great idea. Lithium batteries like to be kept at 20-80%.
Note that the Tacoma uses a 1.87 kWh NiMH battery for the hybrid system. NiMH batteries also do not like to be drawn to deep nor be overcharged.
Lennyz1
Len
NY
I did not know you could remove the battery gauge. I thought it is part of the MAX gauge.
k1m
Nathanial
usa
This is what I have:
2024 Tacoma How to fully charge the hybrid battery for ๐Ÿš€๐Ÿš€BLAST OFF ๐Ÿš€๐Ÿš€ IMG_0914
I have to go to a different gauge to see the 12v.
Lennyz1
Len
NY
Yeah, I skipped the part of the 12VDC gauge.
You probably are viewing a different type of screen. I cannot remember the 3 different types of screens, But my view is exactly what @turnermier is showing.
MustardTiger
TacoMAX/SDuty/Dmax
For those wondering about the gauge...you need to change the type so it's one dial in the center
As for Tow/Haul mode charging the battery fully...didn't work for me, other than keeping the engine running full time
  • Like
Reactions: Ron
Hatman
Jeff
Argyle, TX
2025 Tacoma Trailhunter / 2022 Bronco Badlands
How did you get the 12v battery gauge on the same screen as the MAX gauge?!?!?
did this pop up in a software update I missed?
Switch your Meter Type from dual to single.
sethrog15
Seth
Austin, TX
Underground 2024 Tacoma TRD Pro
lol. Apparently the different screen types lead to different gauge options. I just didnโ€™t explore deep enough. ๐Ÿคทโ€โ™‚๏ธ
I feel like I just need to sit in my truck for a few hours and touch buttons
Greg
Denver
2024 Tacoma Hybrid Limited
I havenโ€™t tried your trick of enabling TOW/HAUL mode to max out the hybrid battery. Iโ€™ve found SPORT S+ works just as well for maximizing the charge level.
I run SPORT S+ mode essentially all the time because Iโ€™ve found that it both maximizes battery charge and delivers the best gas mileage of all the modes.
The trick is in slightly adjusting how I drive the truck, a driving behavior my dad used to call โ€œaccelerate/brakeโ€.
With SPORT S+ mode enabled, prioritize a quick burst of heavy acceleration off the line and then coast as much as possible. The truck rewards coasting with more battery bars. With this behavior, I can consistently earn charge bars even in stop-and-go city traffic.
Bravada
S.E. Texas
Using the tow/haul mode, I've got the battery level higher than it's ever been. Thanks for the tips.
I'm in Sport S+ all the time, surprised I haven't noticed higher battery levels. ๐Ÿคทโ€โ™‚๏ธ I'll try harder :wink:
2024 Tacoma How to fully charge the hybrid battery for ๐Ÿš€๐Ÿš€BLAST OFF ๐Ÿš€๐Ÿš€ 2025-08-13 19.18.24
trailhunger
2024 TH
Method 1: Sport Mode down hill with cruise control or use PDA following a vehicle for 10-15 minutes. Don't use the brake.
The truck will use the motor to brake which will fully charge the battery.
Method 2: Tow/Haul mode. Will fully charge while driving on a flat road, it seems to me that the truck saves the battery life for hard acceleration or uphill climbs. It's also keeps the engine running while at a stop.
After it's fully charged, switch to sport mode and blast off to the Moon ๐Ÿš€๐Ÿš€๐Ÿš€๐Ÿ‘จโ€๐Ÿš€
Method 3: live or travel through a mountain region, drive ECO mode. Do nothing but descend a steep mtn road ~2-6mi and collect all that energy via adaptive cruise or downshifting and youโ€™ll easily top out the NiMH cells. No need to burn excess fuel to run additive propulsion to the hybrid system. You do need noticeable grade & engine descent tho for this to happen. Regen braking will turn to friction sooner than you think so ride the engine down for optimal energy capture.
I will say on the way back out that excess storage was eaten up in the first 2 miles driving back out (parked right at the base of this pass, engine off, cells topped-off). Thereโ€™s a sweet spot in both time & throttling that gas pedal to redirect the power back into the climb on the way back out. But Ive seen the Hybrid system push full energy into the hybrid motor with half charge, milling about town. Favors a half charge for health & optimization.
EDIT: BEST time to charge your power station from the high output inverter is at the bottom on a descent! (If your power station only collects <600w, really doesnโ€™t matter but ones that pull <1,000w repurpose that for dinner at camp ๐Ÿค™๐Ÿผ if youโ€™re NiMH cells are loaded, youโ€™ll notice generator mode will run quiet without the engine cycling for awhile! Sweetens the deal w/electric camping. So yea if youโ€™re out in the flats boost it in Sport mode before getting to campโ€ฆ
2024 Tacoma How to fully charge the hybrid battery for ๐Ÿš€๐Ÿš€BLAST OFF ๐Ÿš€๐Ÿš€ IMG_0949
holden
Holden
Scottsdale
'24 Toyota Tacoma TRD Pro
Sport S+ Mode? Where the hell is that? ๐Ÿ˜‚ I have Eco, Normal, Sport, and Tow/Haul. Is it only available on Limited trims? How do I unlock Corsa mode?
