tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
I found this really nice plug and Play kit with a high quality OEM plug and hard plastic overmolded resistor.
You could DIY for cheap, but I didn't want to splice any wires
No more annoying Jetsons noise.
you got a link for this?
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
where is the sound making thing located? also the company called it AVAS, what is this thing called? a speaker?
turnermier
oregon
25 trdor hybrid
If you have the air dam removed you can slide your hand up between the skid plate and the front bumper and reach the plug.
If you unplug it without attaching a resistor the truck will throw a check engine light
2024 Tacoma Hybrid speaker / flying saucer noise delete kit installed Hybrid Front Speaker Location
Ron
Samsara
I might get one if it made this noise.
GRIZZLYCOMA
Rodrigo
Los Angeles
TRD Off Road H
Brother, get affiliated with that company, I am about to buy this because of your post.
mountainmike
Michael
vancouver
2026 Trailhunter
I just installed the resistor on the front speaker and it works as advertised. Thanks @turnermier for sharing.
I did notice one peculiar change too. My beeper/alert when locking the doors, no longer works anymore. I have a suspicion that same speaker handled the door alerts as well
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
Same here. Installed mine and the door lock beep is gone. Also, Reverse still makes the hybrid noise but I believe that's coming from a separate speaker.
mountainmike
Michael
vancouver
2026 Trailhunter
Good to know it's not just me. My rear has a speaker too, behind the rear steel ARB bumper, offset from the midline to the right a bit. I might try putting duct tape over that speaker, to at least mute it.
Eventually, I'm gonna try connecting a relay switch to one of the Aux ports so Can activate it on or off. I asked my Ai to put together instructions/diagram and it seems like an easy ish install.
2024 Tacoma Hybrid speaker / flying saucer noise delete kit installed wiring_hybridspeaker
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
i'm going to check with the company to see if they can make one for the rear and maybe combine the two in a kit.
GRIZZLYCOMA
Rodrigo
Los Angeles
TRD Off Road H
I didn't know there was a second speaker in the back, I taped the front one and did helped a lot lol. I don't think I want to miss the locking noise
max911
max
AB Canada
"Reverse still makes the hybrid noise but I believe that's coming from a separate speaker."
yes, there is a speaker located near the rear most cross member and frame rail on the passenger side.
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
Found the second speaker and contacted MegaOhm. They’ll be making a kit for future Taco Owners who want to take care of the sound front and rear.
Losing the lock sound is acceptable to me because it also means I lose the rapid beep telling me to check the rear seat. I still get the flashing lights and phone notification.
2024 Tacoma Hybrid speaker / flying saucer noise delete kit installed IMG_1123
2024 Tacoma Hybrid speaker / flying saucer noise delete kit installed IMG_1122
FYI, you can turn the rear seat reminder warning/beeps off in the menu on the instrument cluster.
GRIZZLYCOMA
Rodrigo
Los Angeles
TRD Off Road H
Thank you for the pictures, when that kit comes out, I will give it a try. I am currently taping up that speaker lol
