crepr12
NEast
2025 Limited Hybrid
So no one will hear you while driving under battery power?....ok
Dadbodv1
GIZMO
Idaho
Could drive in tow haul mode would keep the truck from turning on amd off along with jetsons noise coming on.
turnermier
oregon
25 trdor hybrid
The fan is pretty loud and you can still hear the hybrid motor... Trust me there is plenty of noise without this thing.
turnermier
oregon
25 trdor hybrid
I'm fairly certain they are required to emit some sort of sound while driving for pedestrian safety.
It makes plenty of noise without this... There are some non-hybrid 4cyl vehicles that are quieter.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
True. If I had my druthers, I’d change the sound from Jetsons to riffs from the bands of Donna Summer, Joan Jett or Prince. Oh, I’ll be modern and add Taylor Swift.
HarryDaHamster
Zimbabwe
2024 Trailhunter
Trying to make sense of this. You installed a resistor in place of the hybrid noise maker? Where can i buy that resistor?
Paul
Roseville, CA
25' SR5 4x4
Yes, it's required by the DOT for that reason. By disabling it, if you are in an accident and the Insurance Co. Finds out... might not be the best move.
MustardTiger
TacoMAX/SDuty/Dmax
Is it easily accessible crawling under the front of the truck? I'm probably going to try a piece of gorilla tape over it first, should cut the sound at least by half. Works well for backup beepers on equipment
turnermier
oregon
25 trdor hybrid
You can easily slip your hand between the skid plate and the front bumper.
I tried gorilla tape and it actually worked pretty good..
