Interesting Comment from Car Care Nut
MJB4450
2025 SR5
I've been doing my own oil changes but I just watched a Car Care Nut episode where he was showing a friend with a 2026 Tacoma how to do an oil change. Apparently the friend had gotten the free oil changes at the dealership before. After they pulled the drain plug he showed the customer the mangled, deformed and excessively worn gasket and had to scrape the plug to remove the residue. According to him, the dealerships don't use new gasket rings, just reuse the old ones. Has anyone who got the free oil changes and now do their own noticed this? I'm wondering if this is a common dealership thing or just some. Car Care Nut seems to indicate it's common.
TacoBirdinNW
2025 DCLB SR5
I'll check here in a few. Used up my free changes every 5K and am about to put a Fumoto in. Would be interested or hear other folks' experiences
IDontWorkForTheWaterCo
2026 Tacoma SR
If it's in good condition, I'll reuse it. I've done 2 OCs on my 26 and have not replace it yet. I once had a Tercel many years ago that I literally never changed the entire 8 years of ownership. Probably reused the one on our Sienna for at least 4 or 5 years. As long as its not deformed it's fine.
I have a bag of them around. If I do an OC for someone other than my own vehicles, I will replace it. But for me, it's an as needed basis only. In hundreds of OCs over the last 40+ years, I've never had one leak.
iron.head
Michigan
2025 Tacoma TRD Off-Road Premium
It costs nothing and for me it is cheap insurance. On some motorcycles when I do not use a torque wrench I can feel it when the washer starts compressing and is a good time to stop.
MJB4450
MJB4450
2025 SR5
I did the third oil change myself. After exhausting the 2 free ones. The dealer had not used a new washer but of course I did.
That's real confidence building that the dealership would not spend the five cents it cost them for a new washer. Like I said, the one Car Care Nut pulled off was very mangled. I suppose they also over torqued the plug too. I'm glad I just did my own from day one. I was going to get lazy and have the dealer do them but I guess not.
Will721
Quad Cities
That's the sort of thing thats going to depend on the dealer and technician. When I worked at a local Ford dealer, they replaced them free as policy. The GM one I worked at did not. But even then it falls down to the guy doing it. Some were too lazy to do it every time (extra trip to parts), there were a couple techs at GM that did it anyway out of principle. I always changed them on customer cars if they showed signs of wear. But then on my personal rigs I always forget to buy a new seal. 🤣
PNKTACO
2024 Tacoma Sport
As a Mercedes-Benz technician, I replace the washer on every customer’s car. You have to. They’re copper and deform when installed making them single use. If you reuse them, it’s almost guaranteed to leak. I had a 2020 Camry with 105k miles on it that I bought new. Did all the oil changes myself. Never once replaced the drain plug seal. Never once had it leak. I just did an oil change on my ‘24 Sport. Didn’t use a new one either. Doesn’t leak. My question is, if the dealership didn’t use a new seal and it didn’t leak, where’s the problem? Is it worth feeling any kind of way that there’s nothing wrong with your truck?
shuo
shu
Seattle
2026 TRD Off-road Bronze Oxide
I just changed the oil in my friends Kia and the factory marking was still on the plug like it was never touched. The suv has 20k miles and apparently they suck the oil out of the dip stick tube.
DyingBreed
Albuquerque NM
2025 Tacoma TRD Off Road / 2026 4Runner TRD Off Road Prem.
I am pretty sure that is dealership dependent. I specifically asked my dealer to replace mine as I was willing to pay for one at my last oil change a month ago, and they told me they replace the washer on every oil change.
ilie
ilie
california
2026 Tacoma SR white
I had a Fumoto valve on my old truck. Nothing wrong with one if you have the time and patience to wait till empty pan. As my house is located, my driveway sits on a constant brize and the thinner oil discharge was always pushed outside the catch-pan. Afterwords I had to clean oil stains. Clean hands I liked, it's true. Takes longer to empty, that's all.
TacoBirdinNW
2025 DCLB SR5
Thanks brother ! Had not considered drain time, good thought. I'm always making a mess when I change oil, so hoping this will be cleaner.
socaltubbs
Clint
Ventura County, CA
2025 Toyota Tacoma TRD Offroad
I think there is always a possibility of someone at any shop trying to take a shortcut. If you DIY the oil changes and don't have a new washer try this: Rub the washer flat side on both sides on a fine mill file, it will flatten the compression ridge that seals against the pan. Again, a new washer is the best, but this has worked for me in the past.
Some dealers might do oil changes right, but I don't trust any of them to do mine. My wife almost lost the engine in her Infiniti SUV because the tech put a new gasket on the drain plug and didn't notice that the old one was stuck to the sump. The plug backed out and it lost all of its oil but we caught it before the engine seized. The weird part was talking to the service manager. He wasn't even surprised and he had two theories about which fuck up had happened to our car. At that moment I knew why no dealer will ever change the oil in one of my vehicles.
