TRD off Road MPG
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
Pull the rack and bars off and see if that makes a difference. If it does, then you can decide which is more important, fuel efficiency or having them mounted all the time.
I have a smartcap with a low-profile rack on it that costs me about .5mpg so I don't care. If I ever decide I need a rack on the cab, it's going to be one where the crossbars can be removed.
I do a 1000-mile round trip every couple of months to see family (~400 mi country highway 55-65 mph, 600 mi freeway 70 - 75 mph). Last time I checked I got 22.8 mpg.
Only other thing I can suggest is to find a 50+ mi stretch of highway with few or no stops and little traffic. max 65 mph if possible. Fill tank and reset trip odometer and mpg meter. Do a round-trip using cruise control to manage the throttle (set acceleration to low in settings). Then fill up again and calculate mpg.
That should indicate whether its driving conditions or something about the truck itself.
ejosesa
Joses
los angeles
tacoma off road 4x4
25 ORp non hybrid.
Method 305 17” with 285/70/17 Nitto Terra grapplers.
City: 16-18, depending on conditions.
Highway: 17-20, depending on conditions.
gpburdell
GA
3G Tacoma
She's driving a heavy vehicle with the aerodynamics of a shipping container.
My 3rd gen averages 18mpg, and that's more highway than city.
izzy
Bay Area
2024 Tacoma TRD off Road MPG 1000004984
Freeway drive TRD OR wheels and tires on an SR, full skids under and no air dam, Diode lights on the bumper. Was going less than 70 the whole drive, had a few slow downs to 30mph.
you guys gotta slow down lol
also oncoming wind will demolish your mpg, it basically stacks the speed of your truck
65mph + 15mph wind = 80mph equivalent, which means you're gonna get about 20mpg if not less at 65.
Texas Bob
Bob
6k on a 6MT Off-Road, averaging ~20.5mpg which I find acceptable given the capability of the truck. Still on stock tires though.
Most accessories so far have added weight, but some seem to offset the weight through reduced aero drag.
Tonneau cover slightly improved mpg, and despite the millercat steel skid plates adding weight, mpg remained the same.
My 6MT is getting about the same as Andrace's. I do think the tonneau cover is helping a little.
mattski2112
Georgetown, TX
I’m pretty happy if I can baby the throttle enough to get a tank average north of 17.5 mpg (and it’s usually less). Wheels, tires, skid plates, air dam removal all contributed to the decline, but at least my truck looks good. 🤓
The real mpg killer are the highway/tollway speeds around here. 90mph on open stretches is super common.
Liquidassets
Bronson
Louisiana
2024 Tacoma TRD off-road
Stock TRD off-road.
I started with 17-18mpg. Now I'm averaging 20 mpg
Irvin
JC
2024 Tacoma Trailhunter
Take off the roof rack and you'll likely increase around 1.5mpg. Sure it looks cool but a lot of people seem to never or rarely use it.
You mention "light" roof rack, the weight has almost nothing to do with it, any roof rack at all seems to increase wind resistance a lot.
jetmech879
Jon
Sophia, NC
2024 Tacoma, 2025 Sienna
I’ve only got 800 miles on mine but so far after 2 fill ups I’ve averaged 20.7 with both. Have you checked your tire pressures? 5 psi can make a pretty big difference. Mine are around 37psi and I’m thinking about bumping them up to 40. I also just added the hard Toyota tonneau cover. Overall I’m pretty happy with the MPGs in this truck.
gpburdell
GA
3G Tacoma
What does the label in the door frame recommend for tire pressure?
Overinflated tires tend to provide less traction and wear unevenly, as well as increase risk of blowout if you hit potholes or road debris.
I'd stick to a max of 10% above the pressure recommended by Toyota or tire manufacturer.
jetmech879
Jon
Sophia, NC
Great point. For some reason I thought they were supposed to be at 35 but the sticker says 30psi cold. So I will leave them where they are at.
