Trying to upgrade this sound system is terrible.
SpartanCaptain
PA
2024 TRD Sport
I have been installing stereos as a side hobby for 25 years. I have won competitions. I am competent. I have to keep telling myself this stuff as I am in agony over trying to get this system to sound good.
I have a 2024 TRD sport premium with the JBL system. I figured I would start easy and get the trail grid pro alpine speaker set. Thinking it may be enough for me. Nope its a downgrade running off the stock JBL amp. The stock amplifier can't power the speakers adequately. 90% of the sound comes out of the center channel. And if I remove that the sound is just lacking over all. Have to crank it up to get acceptable volumes.
Step 2, PAC adapter and amplifier. Problems continue. At first the pac adapter had no output to the left channels. I reset it which fixed that issue.
For 15 minutes the system sounded great. The amplifier really woke up those alpine speakers. I turned the truck off happy. Go for a ride that night and everything is shit. The sound I heard before is gone, replaced by an echoey sound from the highs, and basically no sound from the lows. I had to crank up the gain on the midbass just to get something acceptable. I don't know what happened. Either the amplifier or the PAC adapter is bad or this truck is pulling some tricks to ruin this upgrade.
Step 3, Under seat subwoofer. Another fail. I bought the Alpine RS-W10D2. This should be about the best shallow mount subwoofer you can buy. I order an underseat box on ebay and install it. I can't even hear it. It is wired to 1ohm and receiving 700wrms but is inaudible. On top of this the seat is not usable. If I lower it, it will sit on top of the subwoofer causing instant damage.
I am now about 2k into this and am close to just reinstalling the factory system. I don't know what else to do. I ordered a replacement amplifier to test that. I also ordered the alpine type s 4" dash speakers to replace the crap ones that come from trail grid. I will probably have to return the PAC device and get a different one to eliminate that as the problem as well.
All in all. 3 out of 10, would not recommend.
Vidman
Rick
Mass
Audio dynamics mk 1000.6 amp, stinger wiring kit sk4241, stinger ssib6, audio dynamics dsp812-hifi, metra speaker wire kit with all speakers swapped out to focal. The system will rattle all the windows… about 3k
Miqie
2024 TRD Sport-Bronze oxide.
The overpowering front center speaker has been an issue since the 4G was introduced. Would a software upgrade from Toyota fix this, not that it's ever going to happen. Was just wondering if this is more of a hardware issue or a software issue.
grwil67
Gary
Louisiana
I saw this video a short while back.
This is basically just giving the volume knob some more leverage.
If you want a decent sounding sound system in this truck you're going to need to rip the entire stock system out, replace the speakers AND replace the AMPLIFIER.
Dirt
Greg
Eastern OR
My hearing aids cost about $7K and I can't distinguish many words in a country song. Life is grand with a good audio book. I probably shouldn't contribute on this thread:fistbump::lipssealed:
grwil67
Gary
Louisiana
I am a total rocker and my sound system if GREAT!
Wife has had Cadillacs and Limiteds of all brands and all have had great sound systems. This Tacoma Limited is no less! Maybe some were a smidgen louder but this is definitely loud enough and again sound is great.
Maybe equalizer needs tuned to a preference....?
Surely all were created and installed equal. @ least the Limited with the JBL is GREAT!
trailhunger
2024 TH
My TH sounds great w/o the SSB removable speaker. Par for a $65k vehicle. A little tweaks on balance & low ends and it’s dialed for me. I used* to be an audiophile, owned 11k vinyl, mag planar headphones, $500 styli for prized records…but your ears eventually wear out like those vinyl grooves.
The removable dash speaker on its own is superb. I only take it with me when camping, also a safety thing in the city.
Miqie
On a related note, when I got my hearing aids a couple years ago ( I don't wear them full time), the hearing doc told me that the aids only work in the 100-7000 hz spectrum, the human voice. They are not good for music listening. That's why I don't wear them in the truck because music sounds awful with them.
wire4money
Tim
Las Vegas
2024 Ice Cap SR5
This won't do anything for the JBL system, it just makes the volume slightly louder at each level.
Not entirely true. Because the factory stereo neuters the signal the louder it goes, when you amplify the signal, it is less neutered at the same audio
SpartanCaptain
SpartanCaptain
PA
2024 TRD Sport
This device works as a preamp. So as the factory system rolls off bass this amp will also roll of bass the same amount. All it does is provide a higher voltage to the JBL amp. It cannot change roll off of frequencies.
grwil67
Gary
Louisiana
Sounds like it works exactly as advertised.... "Preamp" for a little boost.
MHG
Mark
Long Island
2025 TRD Offroad
Unfortunately these modern vehicles with these large infotainment screens are not friendly to traditional car audio. They tend to come with systems that are ok sounding at best with no dash space for a third party head unit.
There are several marine systems that have small controllers that may be of use. One company Memphis Audio, makes what they call Black Box Media Controller with App Control. While it’s no alpine or other high end head unit, it is fully remote .
wire4money
Tim
Las Vegas
2024 Ice Cap SR5
I understand that, that’s kind of my point. Since you are amplifying a signal with less roll off, it is less neutered. If you typically listen at sound level 25, but now with the Beatsonic you now listen at 15, there is less roll off with the same output.
