JustDSM
Justin
Ogden, UT
www.overlandtailor.com
2024 Tacoma TRD Offroad
At Overland Tailor Tuning (OTT), we're committed to delivering cutting-edge solutions and accurate information for your Toyota tuning needs. During our research and development—along with valuable feedback from the community/customers—we’ve uncovered a critical issue that 4th Gen Tacoma owners interested in fitting the TRD intake to their non-Pro or Trail Hunter:
TRD Pro and Trail Hunter Intake Systems are NOT plug-and-play with standard Tacoma models, including non-Pro and Trail Hunter hybrid models.
While these upgraded intake systems are popular for their performance and rugged design, they cannot be retrofitted to non-TRD Pro, Trail Hunter, or hybrid Tacomas without custom calibration. Here’s why:
  • Physical Differences in Airboxes & MAF Housing: The internal geometry of the airbox and MAF sensor housing in these systems is significantly different from stock Tacoma configurations.
  • Calibration Required: These differences disrupt the MAF sensor’s ability to correctly measure airflow, resulting in fueling errors, poor performance, and triggering the dreaded Check Engine Light (CEL).
What This Means for You
If you’ve installed—or plan to install—a TRD Pro or Trail Hunter intake system on your 4th Gen Tacoma, a custom calibration is essential to avoid:
  • Incorrect air-fuel ratios
  • Performance degradation
  • Potential long-term engine damage
OTT’s Upcoming Solution
At OTT, we specialize in creating custom calibration solutions for Toyota vehicles. We are excited to announce that not long after the release of the 4th Gen Tacoma tune, we plan to offer MAF calibration services specifically for this swap. These calibrations will ensure seamless compatibility between TRD Pro and Trail Hunter intake systems and standard 4th Gen Tacomas, including non-Pro and hybrid models.
Stay tuned for more updates as we continue to refine and expand our offerings to meet the needs of the 4th Gen Tacoma community. The release is not far away!
JustDSM
JustDSM
Justin
Ogden, UT
As promised, we have an update for you with developments on this topic.
We have successfully reworked the MAF calibration for the TRD Pro & Trail Hunter airbox to allow use and retrofitting on non-Pro & Trail Hunter models.
We're pleased to announce that we'll be able to offer calibration support for the TRD Pro & Traill Hunter Airbox retrofit at our initial product launch.
AZTaco
AZ
2025 Tacoma TRD Pro
Well the million dollar question is, if the Pro/TH intakes throw codes in non Pro/TH Tacomas because they flow more, then how does the hp/tq curves differ when recalibrated?
Toyota doesn't show a hp/tq gain for the Pro (but does show a decrease for the TH - snorkel more restrictive?). Is there more power under the curve?
JustDSM
JustDSM
Justin
Ogden, UT
We've gathered the calibration data for the Pro/Trail Hunter (TH) airbox and will be putting it on the dyno soon to provide performance data.
One important takeaway is that the Pro/Trail Hunter airbox has a higher airflow ceiling before the MAF sensor reaches its limit. This means it can measure a greater mass of air over time, thanks to a larger metering section in the housing compared to the standard airbox.
Since the Pro/TH airbox includes a separate fender duct (which can be capped on the Pro), it's reasonable to assume it offers greater overall airflow capacity than the standard intake. While we haven’t specifically tested restriction levels yet, the Pro/TH airbox is likely less restrictive than the factory airbox.
Why This Intake Triggers a CEL on Non-Pro/TH Tacomas
The Check Engine Light (CEL) isn’t caused by the higher airflow alone—it’s due to how the ECU processes that airflow. The Pro/TH MAF housing is physically larger, which means the same MAF sensor frequency now corresponds to a different mass of incoming air than the ECU expects to see.
Because the stock ECU is calibrated for the standard airbox, swapping to the Pro/TH intake without adjusting the MAF calibration causes incorrect airflow readings and fueling calculations. The ECU attempts to correct the error with fuel trims, but it triggers a CEL when the deviation exceeds the allowable threshold.
Solution: Proper MAF Calibration
Custom MAF calibration is required to use the Pro/TH airbox on a non-Pro/TH Tacoma without issues. Updating the ECU’s airflow tables ensures it correctly interprets the new housing’s readings, restoring proper fueling and preventing CELs.
Upcoming Testing
Along with dyno testing the Pro/TH airbox, we’ll also be testing it against another aftermarket intake specifically designed for non-Pro/TH models. This will give us a better comparison of airflow characteristics, performance gains, and how each intake interacts with proper MAF calibration.
With the calibration data in hand, we'll be sharing results soon!
Awger
Kelowna BC
24 Tacoma
I'm wondering if swapping out the air box on the TH for the Pro version would be plug and play then?
Devildog81
minnesota
2024 tacoma trd offroad
Upcoming Testing
What about the other air boxes on the market like, sxth element, afe, k&n and S&b? Are they going to need a separate calibration with your 4th gen tune?
JustDSM
JustDSM
Justin
Ogden, UT
We've specifically tested the Sxth Element intake and the unit we evaluated did not indicate it would require custom MAF calibration. There was an increase in the dispersion and overall mean error, but it fell within acceptable range of tolerance (that we're comfortable with).
We've purchased an aFe Momentum GT intake to evaluate as well. I'm not expecting anything different than what we observed with the Sxth Element intake. But we'll keep you all posted should our findings prove otherwise.
Once we can get our hands on other brand intakes, we'll test those too.
JustDSM
JustDSM
Justin
Ogden, UT
The Trail Hunter and TRD Pro intakes can be swapped without any custom tuning required (assuming you have a TH/Pro). The intakes are identical in the areas where it would affect the calibration data. The main difference is the logo on the exterior of the box.
rougesix29
Oregon
2024 Toyota Tacoma sr5
Upcoming Testing
What about putting a k&n performance intake with the mandrel bend aluminum performance pipe?
JustDSM
JustDSM
Justin
Ogden, UT
We've not tested that intake yet, but from anecdotal report,s it appears ok to use without causing a limp mode/CEL condition.
rougesix29
Oregon
I’ve been running it for about 4000 miles and seems to be good. No cel. Just was wondering
AZTaco
AZ
2025 Tacoma TRD Pro
Upcoming Testing
What happened to this testing? Do we have results? Thanks
JustDSM
JustDSM
Justin
Ogden, UT
We did test it.
A few months back, we ran the TRD Pro intake with the fenderwell plug removed—configured the way most people would likely run it (for maximum airflow and sound). Testing was done on both the stock calibration (with TRD Pro-specific MAF scaling, no other changes) and on our Stage 1 file (again, with appropriate MAF scaling applied).
When compared directly to the stock airbox, there was no measurable improvement in output at Stage 1 power levels or below. The dyno runs all overlaid on top of each other, whether using the TRD Pro airbox or the OE setup with the stock paper filter. From a performance standpoint, at these power levels, the TRD Pro intake doesn’t add anything. That said, it does offer a nice sound and has some visual appeal under the hood.
Where this intake may become relevant is in its higher airflow ceiling. Thanks to the larger MAF housing, it can meter more airmass accurately than the OE airbox. If/when people start pushing this platform harder, that additional headroom could make it a worthwhile upgrade.
We’ll know more very soon—our bolt-in turbo upgrade is arriving tomorrow, and that’s where a setup like the TRD Pro intake could really start to show its strengths.
I’ll post up the graphs once I get back on the PC with the run files. Appreciate the patience!
HarryDaHamster
Zimbabwe
2024 Trailhunter
I know the Trailhunter intake flows significantly less than the other models. I plan to get a Stillen intake and retain the snorkel. I assume you can calibrate for the higher flow. Correct?
I plan to get a OTT tune soon.
JustDSM
JustDSM
Justin
Ogden, UT
The Stillen intake uses a MAF housing diameter that's very close to that of the Pro/Trail Hunter. If you fit the Stillen intake onto a Pro/TH, no special scaling is required. Our Stage 1 calibration will get you sorted out just fine.
When fitting the intake to a non-Pro/Trail Hunter (gas or hybrid), the specific scaling option we offer will prevent CELs and is required if using our tuning.
