4-LO High RPM's. Am I missing something?
Zanez
Zane
Cali
Has anyone noticed that the 4-LO option on the 2024 TRD Off-Road feels like it is geared too low. I want to shift up cause it revs up so tight. Am I missing something? I've never had a truck move so slowly in 4-LO. You can't get a good run going in the sand. Going too slow is going to get me stuck.
Zanez
Zanez
Zane
Cali
That is usually a good thing, 4Lo is intentionally geared low. If you are blasting through sand or need more speed use 4Hi
I understand what you're saying. I'm just saying none of the many trucks I have owned have been geared so low. My son drives his 06 TRD in 4 lo all the time when we're hunting and you can't even tell it's in 4-lo.
NewtoToyota
Georgia
24 TRD Sport
That sounds more like an issue with your son's truck than yours. It should be a very noticeable difference between the two. My old jeep rubicon was geared so low I could tackle most obstacles without touching the gas pedal.
Zanez
Zanez
Zane
Cali
His truck gets around great and he doesn't have a problem in the sand with his "high geared" 4-lo. I can crawl and get most places but it's bit me in loose and soft sand.
NewtoToyota
Georgia
24 TRD Sport
Again, my best advice is switch to 4Hi if you need wheel speed. Traditionally, trophy trucks which race through sand, are 2WD. Use 4Lo when you need the lower gearing
Mtn.Ta_CO_man
Stephen
Tacoma Off Road i-Force Max
There is always the manual shift option?? If 4-lo 1st is too slow for you, maybe try 2nd or 3rd?
I walk faster then my old jeep moved if I just let the idol take it forward in 4-lo. Haven't tried it with the truck... yet. ?
Zanez
Zanez
Zane
Cali
Have you got a manual or automatic? I'm sure its similar in the 8A, but in the manual you can still get some pretty substantial speed out of 4Lo.
Max speeds in each gear - 6M
1st - 8mph
2 - 17
3 -29
4 - 42
5 - 55
6 - 67
Automatic...It's wound up pretty tight at 17 mph.
TexasBlueCrush
Tex
4th gen TRD Sport 6MT before that 3rd/2nd gen TRD Sport 6MT
1st - 8mph
2 - 17
3 -29
4 - 42
5 - 55
6 - 67
No freaking way. Maybe you meant four-high yes ? I have a 6M but have yet to test out 4L. What i can tell you after burning across 3-states last week in snow-pack and ice-pack on the interstates, I was running as fast as 65mph in 4H.
Zanez
Zanez
Zane
Cali
Its straight from the owners manual. Page 222 under the "Manual Transmission" section. Mind you, this is probably at or near red line RPMs.
Sounds great if I had a manual but I have a automatic.
theKurt
Kurtis
Calgary, Canada
2024 Tacoma Sport+ 6M
Yeah, sorry. TexasBlueCrush was uncertain of where I got that speed info.
As for the Automatic....I don't know for sure. It should shift up into 3rd at some point to give you more speed. Here's some info I found in the owners manual, but I can't find anything that specifically limits you to 2nd or 18mph or whatever in 4LO.
-In Automatic transmission "Sport" mode - you've selected 2nd gear, but you should be able to select 3rd yourself by pushing the shifter forward.
-MTS doesn't seem to have any posted limits on what speed you can go, but this might be a factor
-Stability bar disconnect only activates below 18mph. I dont think this is your problem though.
-Stability Control or Traction control would limit the transmission or engine output if it thinks its slipping. To disengage both the stability control and traction control completely: be stopped, press and hold the traction button for at least 3 seconds. All traction aid limits are off and you can run wild.
If you've covered all of this, then I'm not sure what could be wrong.
