I'm hearing apparently they added front tow hooks for 2025 to all models, is this something that can be upgraded
Bravada
S.E. Texas
I have a 2024 Sport and I added a RCI crossmember so that I could add a OEM skid plate. The OEM red tow hook hits part of the crossmember and I had to crank down the bolts to get it to sit flush. I think I was at about 70ft lbs. it looks straight and flush. Has anyone encountered this issue?
75 lb-ft. is the torque spec for them. Guess they needed to be at spec. torque. ?‍♂
GFGarage
Anyone know the actual torque specs for the OEM front tow hooks on the off-road? I took mine off to paint them but I don’t trust the torque specs I find online after putting my factory predator steps back on (until I get some sliders) and snapped a bolt torquing it down to the spec found in a Toyota installation guide I found online. So I went to hardware store and bought all grade 8 bolts. Wondering if I should do the same especially with the tow hook hardware
Bravada
S.E. Texas
I've taken mine off and on several times at the 75 lb-ft. spec. Even Sxth Element marks theirs for 75 lb-ft.
2024 Tacoma I'm hearing apparently they added front tow hooks for 2025 to all models, is this something that can be upgraded 1744948798274-v0
cyranodabum
Orange County, CA
2024 TRD OR Hybrid
I agree that the factory hardware doesn’t seem to be the best. I rounded off one of the nuts when doing the exhaust delete. Given that it happened during removal and not tightening, the torque spec wouldn’t have helped me though. My “solution” was to order these front recovery points so that I could get free shipping on a replacement nut. ?
Bravada
S.E. Texas
Is Sxth Element a legit site? I put in an order for the front and rear recovery hooks about a month ago and no word yet…
I've ordered and received their CAI and the rear recovery points. I haven't a clue why you are having issues with your order. I feel their products are high quality, so your issues are unexpected.
2024 Tacoma I'm hearing apparently they added front tow hooks for 2025 to all models, is this something that can be upgraded 2025-04-10 21.17.46
2024 Tacoma I'm hearing apparently they added front tow hooks for 2025 to all models, is this something that can be upgraded 2025-04-04 16.56.40
