Speedometer calibration after tire and wheel size change?
jamesavery22
Northern VA
24 Tacoma
Has anyone else addressed this? SR5 with stock tires is consistently 2-3mph faster on the speedometer than GPS. I won't be putting larger tires on. Is there any calibration that can be done?
TrailAdventurer
JT
Canton, MI
I doubt the speedometer is 100% GPS based, but maybe it can compare the speed based on wheel speed vs. the GPS speed periodically, and re-calibrate itself for a new wheel size?
Vehicle speedometer is not determined using GPS. It's determined using the same sensor used for ABS. The wheel speed sensor informs the ECU how fast each wheel's going at any moment in time.
For me, going from OEM to 34s on Riddick, I noticed a moderate change. Vehicle speed is consistently overstated 2-3 MPH compared to GPS.
There are various sites that discuss this, including Tacoma World, Toyota Parts Center, JD Power, and so on. In one article, it indicated it's a rear wheel that is used.
DENNISD
Dennis
Omaha
I have owned many Toyotas and all of them showed that I was going at least 1 mph faster than I actually was. I have heard that Toyota has engineered their vehicles to do this on all of their vehicles. Not sure this is totally true but it has been consistent on my end. I think they are erroring on the safe side so to speak for legal reasons.
In any event, if you are placing larger diameter tires/wheels on you vehicle you may actually be spot on with the MPH after the fact. :wink:
24TacomaGirl
Robyn
All manufacturers always err on the side of caution and conservative readings for legal and liability reasons where mechanical systems are used. Because of this, yes, the factory reads high (overstated speed vs actual) when stock and in fact can become spot on with the larger tires removing the intentional slack from the readings. And then with larger and larger it will continue to deviate past spot-on as would be expected.
HardCorTaco
Cory
Utah
youtube.com
I just did a speedometer test on my truck. I have 34ā€ tires on my truck. The tire size is 285/75/r17. When the truck said I was going 65 MPH I was actually going 68. I have a speedometer calibration tool on order. Is anyone interested in watching a full length video on the install?
BLtheP
TX
The truck is calibrated for the Speedo to be accurate on 33’s and the odometer to be accurate on 32’s. It’s a compromise between all the stock tire sizes.
245/70R17 (31ā€) - 3.5-5 mph fast at 70, odometer slightly fast
265/70R17 (32ā€) - 2-3 mph fast at 70, odometer accurate
265/65R18 (32ā€) - same as above
265/70R18 (33ā€) - spot on Speedo, slightly slow odometer
Non stock:
285/75R17, 285/70R18, or 34ā€ - Speedo 2-3 mph slow at 70, odometer a bit slower than 33’s
It’s really not that complicated of a concept but one has to be paying attention and catch it to understand the nuances.
Congo
Shawn
2025 Tacoma TRD Sport i-FORCE MAX
Non stock:
I have 37's, it is way off.
Congo
Shawn
What did you order?
HardCorTaco
Cory
Utah
youtube.com
What did you order?
It’s from a company called Hypertech. They don’t actually let you buy it from their website. I ordered mine from JEGS but it’s been a few weeks and hasn’t shipped. I’m not confident I will actually get it anytime soon.
https://www.hypertech.com/
Congo
Shawn
Looks like they are still in production.
2024 Tacoma Speedometer calibration after tire and wheel size change? 1780248904825-g0
Robb_D
2025 TRDOR DCSB IFM 1L7
Non stock:
Data point, this information isn’t accurate for my 25 TRDOR iMax. Im presently still on the stock 265/70r18 and up to 50 Iā€˜m about 1mph slower than speedometer indicated, over 50 I’m about 2mph slower than indicated… 45mph on speedometer is 44mph on the gps and 80mph speedometer is 78mph on the gps. It’s an anecdotal data point, but I’ve verified this across 4 different gps units, and multiple street radar signs.
BLtheP
TX
Sounds like they shifted the programming one tire size over from the gas to the hybrids. Because the way yours is is how most trucks come factory.
If you tracked your distance I would bet you’d find your mileage to be spot on.
