Sway Bar Disconnect - Is it possible to add this on later?
ThatBronze4G
Lloyd
United States
2025 Toyota Tacoma TRD OR
Toyota is pretty stingy with them for TRD’s. There just isn’t a lot of them out there? You will be very lucky to get one from car-part!
Airborne
Upstate,NewYork
When i put my deposit down on mine i really pushed my dealer i wanted the sbd, i guess im lucky i got it on mine
ThatBronze4G
Lloyd
United States
From a wrecked vehicle?
yes, if it's been hit in the rear then the bar should be fine. technically i just want one to see if you can activate the motor on it with a few wires and then use an aftermarket switch like a switch panel to control it.
Romer
Ken
Centennial, CO
FWIW, I think it may be pre-wired, but I don't know. There is wiring and a connector where this goes in the console with a blank on top. Talking about the connector on the right end and there is a blank on top
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? 20250603_174334
ThatBronze4G
Lloyd
United States
how exactly do I use this website to find this specific part?
you add year, make, model, and part in the dropdowns. but when it shows the vehicles, you either look at the pictures that they have by the parts or just guess. a lot of times i will end up calling the salvage yards to double check when it says they have the part i'm looking for.
JakeJoeBob
Jake
24' TRD Offroad
Heard it's 7K-8K to add on later from somewhere, when you consider the option is 1100 not worth doing that. I have the SDM, it's a great feature.
iron.head
Michigan
2025 Tacoma TRD Off-Road Premium
Were you able to snag this one? Might not be the one we want but they say it's sold.
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? 1751313613188-dy
turnermier
oregon
25 trdor hybrid
Just wanted to add more information.
Looks like you will also need stabilizer disconnect ECU
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? 1753823217229-75
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? 1753823242784-6
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? 1753823257103-xd
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? 1753823289426-ii
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? 1753823187575-l8
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? 1753823322141-q7
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? 1753823340838-0
2024 Tacoma Sway Bar Disconnect - Is it possible to add this on later? 1753823357841-u1
iron.head
Michigan
Which means practically impossible to retrofit & wait for an aftermarket solution
turnermier
oregon
25 trdor hybrid
You could just install the factory sway bar disconnect and take off the motor... Actuate it by hand when you need it.
iron.head
Michigan
I believe it is a sealed unit. And it is still priced 100% incorrectly as a spare.
