hagglethorn
Russellville, AR
2019 4Runner, 2004 Yamaha FZ1, 2022 Kawasaki Versys SE LT+
Rokblokz mudflaps, paint-matched overlays on β€œTACOMA” on the dash, tray for the center console, neoprene cover on center console, hidden tray on the underside of the console lid, removed bed decals (slight damage to paint that I’m way sad about… :frown:), Offroam phone holder, Screen Protech (glad I got the extra pieces… gonna re-do the dash), and an AJT key fob.
Took off the Rokblokz logo with a utility knife and some sandpaper. (y)
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_3554
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_3555
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_3584
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_3650
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_3651
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_3652
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_3659
nurp42
TRD PreRunner
'24 PreRunner
taco4moro
Los Angeles
2024 Tacoma TRD ORP
RIGID Industries 20" SR-Series Pro lightbar in white spot/flood combo with Amber-Pro lens covers
  • requires some trimming on the oem grille, used Bulletpoint Fab's universal brackets
  • lightbar with the lens cover sits perfectly in the grille
  • true amber lens covers provides protection and modularity, can remove/add them by loosening brackets
RIGID Industries 6" SR-Series SAE fog light kit
  • perfect plug and play fitment
  • didn't opt for lens covers but there is enough space to put them on, will add on in the future
  • these are brighter than the headlights, make sure to properly angle down during install.
will be installing the full RIGID Industries suite over the next few months including: ditch lights, 40" lightbar for the roof rack, chase lights, and rock lights
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_9937
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_9935
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_9936
Slappy
tacoma , highlander
nurp42
TRD PreRunner
'24 PreRunner
do you leave that rack on the truck ?
how easy is it to remove ? reinstall ?
thanx
I leave it on. It's attached using 8 bolts in the T-slots (2 at the base of each of the vertical supports as circled in the pic below). The only situation I can think of where I'd want to remove anything would be needing to fit something in the bed that was taller than the crossbar nearest the tailgate and in that case I'd just remove the crossbar and leave the rest on. Haven't done it, but my guess is that if the 8 bolts mentioned above were loose the whole thing would slide right off the back and reinstallation would require just sliding it back into the tracks and tightening down the bolts again.
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ tempImage4X2upV
Toy-truck
Houston, TX
What did you had to trim on the OEM grille and how much trimming was involved?
taco4moro
Los Angeles
2024 Tacoma TRD ORP
this image is from rave offroad with a 20" baja bar, but very similar situation.
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 1754005556123-ul
the bolts for the rigid light stick out on the side in similar way, but this actually provides some use as the light bar can be loosened without removing the grille, giving me space to remove/swap out lens covers.
