Tire pressure view likes to disappear?
Regius
Reg
New York
2024 Tacoma TRD Offroad, non-hybrid, 5.5 bed, silver
In the gauge cluster, after I have chisen the tire pressure to be a permanent display, what I noticed was it tends to give way to trip meter. I don’t care to see my Tfip B or whatever, would rather always see tire pressure handy. How come it tends to disappear?
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
A known problem, that is not likely to ever get fixed.
Yeah, unless a programmer changes the bad code while working on something higher in priority it's not likely to get fixed. Look at the problem with the fuel gauge "sticking". That, as I understand it, happens on the Tundra as well.
Here's how I deal with it.
1. One time only. Do this while in Park.
Disable all of the options for that display area except TPMS and one other (Trip A for example). Hold the "Ok" button until the display goes into setup mode. Press the right arrow twice. Use the up/down arrows and the OK button to uncheck or check options. Then hit the return button until back in normal operation mode.
2. When you notice that TPMS is not displayed. Hold down the OK button for a few seconds, hit right arrow, down arrow, and return button. I don't even look any more.
2024 TRD Sport-Bronze oxide.
I just use the Toyota app to check my pressure.
GoodMoodley
Ontario Canada
2024 TRD Off Road Premium, 2023 CRV Hybrid Touring, 2015 228i xDrive, 2012 135i
I was just complaining about this to my wife yesterday while we were on a drive. Thought I was doing something wrong.
It’s goddamn annoying - if there is one thing I need on all the time it’s tire pressure and I shouldn’t have to keep clicking around when I’m trying to drive
Echoedlite
Wisconsin
Been dealing with this with my truck all ownership. Especially annoying when these stupid thin walled tires get a single leak.
By trial and error, I've found it always rolls over to the 'previous' screen gauge (one up). Even if you set that side to allow nothing but TPMS, it'll roll over to 'blank'.
As much as it's frustrating and shouldn't be necessary, I've gotten in the habit each time where I didn't even have to think about it:
Long press settings, click over to the gauge, flick down once, back arrow x2, done.
Crazy Mary’s Husband
Chester
God’s Country, USA
Mine always worked properly when I had it set to display double main gauges. When I changed to a single main gauge, it would disappear after shutting the truck off. I put it back to double main gauges and viola, it’s back to working correctly again. Try it out and see if it works for you.
I think I’ve always had double gauges - rpm and mph
Chester
God’s Country, USA
Idk what to tell you but I can switch between single and double gauges and it malfunctions on single and works correctly on double. We can go one more step if it matters, I have the meter style set to to “smart”
I just went outside and started it and made a video to show that it stays there after being shut off.
franx
Frank
Lehigh Valley, PA
2025 Tacoma Limited Hybrid
I was able to get mine to switch to tire pressure only on the right gauge. I then turned off the truck and restarted it and its holding the tire pressure screen for now at least.
So far I've tried all six positions under double gauge and four of six positions on single gauge. No change in behavior.
If the truck is shut off for ~10min or less, gauge stays/sticks
If the truck is shut off for >10min, the gauge doesn't stick and it "rolls back" to whatever is the permitted prior option for that position (if you haven't restricted anything, this'll be "Trip B")
franx
Frank
Lehigh Valley, PA
I just checked mine again and its about 4 hours later and its still working. I will report back tomorrow with any updates/changes
