17’s vs 18’s
DizzyHeaded
Virginia
25 Tacoma
Okay so I’m wondering why everyone is going back to 17” wheels? Does it give you more room for bigger tires or what? I just picked up my 25 trd sport and was thinking of doing 18x9 +20 with a 1.5 level. I see everyone going 0 offset on 17’s running 285. Just curious
added a photo of my ride just because I wanted to
2024 Tacoma 17’s vs 18’s IMG_5436
DizzyHeaded
DizzyHeaded
Virginia
25 Tacoma
Okay I see now. That does make sense now that you mention it.
828findadventure
Eric
North Carolina
2025 Toyota Tacoma SR5, 2021 Toyota Tundra SR5
17" wheels give lots of tire choices. They also give you ample side wall for on road or off cushion. The extra sidewall also gives you more room to air down.
DizzyHeaded
DizzyHeaded
Virginia
25 Tacoma
I had never really thought of it in that way. I thought people were doing just to try to get 35’s without much of a rub.
828findadventure
Eric
North Carolina
The height of the tire, say a 35 on an 17-18" rim will remain the same, but the side wall gains an inch on the 17". That said, you will still get rub with either size rim unless the off set is correct and the vehicle lift correct.
zekesview
Zeke
Walnut Creek, Ca
www.zekesview.com
2025 Toyota Tacoma TDR Pro
Lots of great input here and I’ll also add, I personally like the size of a 17” vs an 18” rim along with the amount of sidewall you get on the 17.
I know I won’t be doing hardcore off-road, technical routes or rock crawling. I will do dirt roads, fire roads, washboards and less technical 4x4 routes so airing down is important. Ride quality is important.
I didn’t go with a true 35x12.5 tire. They’re heavier and more expensive.
Offset is key.
Method 315 17x8.5 +25
Toyo Open Country ATIII 325/70/17
2024 Tacoma 17’s vs 18’s IMG_0310
828findadventure
Eric
North Carolina
Offset is key.
Method 305 17x8.5 +25
I assume the 325 tire fit without rub?
TacoEd
Ed
Denver
2024 Tacoma TRD Pro Hybrid I-Max
Great info guys, I still have my stock 20" and have wondered which route to take
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
Doesn’t matter the size of the wheels is 18 or 17. 35” tires is 35” tires. Mine is a hybrid so it came with a 18” wheels. I went 17” for availability on aftermarket wheels is larger and more variety of selection of tire sizes.
Before and after.
2024 Tacoma 17’s vs 18’s IMG_6692
2024 Tacoma 17’s vs 18’s IMG_1822
rallyprox
Scott
Northern California
2025, TRD Off Road, MT
18” to 17” wheel change is only 0.5” difference side wall assuming same tire diameter. I find it hard to believe that will be a big difference in most real world scenarios. 17” wheels will likely offer more tire options, especially if going for 35” or larger. I swapped to 18” RRW wheels. With nitro Recon Grapplers 285/70 R18. Very happy with ride and noise levels on the road. Only 800 or so miles on the tires, but I am happy so far. Offset is +25. Zero rubbing and no mods to truck.
Picture for reference.
2024 Tacoma 17’s vs 18’s IMG_0703
