Pappy
Intermountain West
In case you missed it. They upgraded the plan a few months ago. $50/mo for 100gb. For $5/mo you can "idle" the antenna which lets you use if for email and emergencies. A buddy uses the $5 plan for just about everything.
2024 Tacoma Post your Starlink mini mounting setup! starlink
CAMTuning
Cameron
New Mexico
2025 Tacoma TRD OffRoad
If you're connected via a cable to the infotainment, you can be on wifi and CarPlay simultaneously.
I never do that- so I'll have to figure out how to use it with the cable.
Will721
Will
Quad Cities
2025 TRD OR
FYI if you already have starlink home, keep an eye on your emails. I received my starlink mini free because I already have it for home use.
CAMTuning
Cameron
New Mexico
I will have to look into this. I let mine cancel for this month because I didn't really have a need for it but I tried to use it and I guess since it isn't idle I don't have any service at all.
Edit- I don't see an "idle" option, and my plan options don't include $50/100gb. I have 50gb for $65:
2024 Tacoma Post your Starlink mini mounting setup! 1775235244425-e4
gofastdan
Do you have the Starlink Mini or the regular Starlink residential? I believe the $5 standby plan can only be had with the Mini, not the residential.
EDIT: NVMD. I'm wrong. Should be able to use it with all Starlinks.
n118nw
San Antonio TX
Taco Supremium
This is the one I've used for about 8 months now; printed in ABS and stainless steel hardware. I take my dish off when I'm not using it.
2024 Tacoma Post your Starlink mini mounting setup! IMG_8343
CAMTuning
Cameron
New Mexico
Mine is the mini.
gofastdan
Mine is the mini.
The only other thing I can think is that you may have to have an active plan before you can put it on "standby". So, maybe pay for a month at your normal rate and then see if it gives you the option of putting it on standby.
I will say, for me standby gives me plenty of bandwidth to read email and whatnot, which is all I care about 90% of the time. I'll spring for full data only when I'm making extended trips with my camper.
